SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
SOURCE: cassettes tapes not moving in my Panasonic RX-ED77
If you can her the motor turning, there is a good chance that the belt(s) have broken and need to be replaced. If you hear nothing, then there could be a control issue. I'm leaning toward the belts though. Figure on $5-$15 for the belts,
Dan
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
SOURCE: playback
when I plug in the RPU DC cord from my camera to the input on my tv I get nothing. Is my input jack bad or what. Also, if I tried the s video jack from the camera to the tv, would that work??? I don't know what the AV out jack is for I don't have a cord for that
SOURCE: denon DR-M44HX cassette deck play
http://www.fixya.com/support/t12006246-ive_got_denon_drr_m30_keeps_poping_back
The solution from AlecBrown133 above fixed the same problem for me. The only comment that I would add is that the same repair can be done with a normal rubber band. I used one to fix the same issue with my Denon drr-m30 and it is significantly cheaper than the 10 pound option.
