Question about Locks & Locksmithing
The batteries are low in my proline digital safe and I cant open it. I do not have a key for it. Help
Posted by Robert Anderson on
Chris Walker
    Top Expert:
  • Locks & Lock... Master
  • 1,551 Answers
Posted on Mar 29, 2019
5 Related Answers
Anonymous
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
Posted on Oct 10, 2009
Bruce Hathcock
  • 3600 Answers
SOURCE: Door locked on safe
Brian We can't give advise on the safe but you can call the manufacture of the safe and if you have registered it they will help you otherwise federal law requires a lock smith to identify you and your information and your ownership of the safe before they will unlock it for you. This is to protect you or the safe owner and the lock smith from being sued and losing his licence.. There should be a sticker on the safe with a 800 number for you to call to get help. But you must have registered it first. They may have a way to verify it some other way but am not sure.
Posted on Nov 22, 2009
Anonymous
SOURCE: i have a cs-2 digital safe batteries dead cant
Try taking a 9 v battery and hold the terminals against the metal frame of the safe. If this works you should be able to enter your code and get her open. Then you can replace the 4 AA batteries on the back of the door. Good luck
Posted on Apr 18, 2010
SOURCE: can not open my safe, sentry 3750
Sounds like all you might need is a new Sentry Safe battery pack to hold the batteries. As these sometimes short out from leaking batteries.
Posted on Aug 09, 2010
joanne_tomli
Deb Kemp
SOURCE: i have a digital home
i have digital home safe 701-5359 and left keys inside and batterys have gone
Posted on Jul 22, 2011
I have the key I know the3 combination but still i could not open because it's in low battery
if you know the battery is low then you need to open your safe using the keys and then change your batteries as the safe won't open using your 3 digit code if the batteries are low.
Jan 03, 2013 | Safe International Digital Electronic Safe...
I cannot open my Noble safe with the code I had. It seems that my code is gone and I don't find the key to open the safe. What can I do ? songa
I cannot open my Noble safe. I havent used it for 1 year, it has no battery and cant open it with my key. I cant remember the code, but i wont be able ti use it with no batteries.
What can i do
Feb 23, 2011 | Safe International Digital Electronic Safe...
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
I have a cs-2 digital safe batteries dead cant find key help please
Mar 15, 2010 | Safe International Digital Electronic Safe...
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
I have a bunker hill safe digital, and battery is too low to open the safe and cant find my key, probably inside, any suggestions
If you have the small electronic Bunker Hill safe with lost keys and dead batteries, this is a potential solution... Take a hammer and strike the top of the safe while attempting to open at the same time. You may need to place on object on top of the safe such as a flip flop shoe to strike with hammer to smooth out the pressure when striking. It should pop open after several attempts.
Jan 25, 2009 | Check Point Network Adapter
Locks & Locksmithing Logo
272 people viewed this question
Top Locks & Locksmithing Experts
john h
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
