Question about Onkyo Audio Players & Recorders
Onkyo ht-r590 usb mode playing mu7sic,after i often the factory reset switch to power on no sound at all.
Posted by Macadoo Centeno on
5 Related Answers
Anonymous
  • 319 Answers
SOURCE: Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Posted on May 07, 2008
Anonymous
  • 3 Answers
SOURCE: Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
Posted on Jan 19, 2009
Anonymous
  • 4 Answers
SOURCE: Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Posted on Jun 25, 2009
Anonymous
SOURCE: onkyo receiver memory power backup not working
How change battery and the battery model
Posted on Feb 04, 2010
Anonymous
SOURCE: I have an Onkyo HT-S6100 home theater not sending picture to TV.
I just fixed mine with the same problem. Apparently, the HT-R667 and 606 receiver that comes with 6100 has a problem with the HDMI board. Onkyo wanted $500 dollars to fix it, costed me $16. Here's how to fix it. http://www.highdefforum.com/high-definition-receivers-recorders-players-tivos/121956-repairing-onkyo-htr667-aka-606-a.html
and the youtube vid: http://www.youtube.com/watch?v=gj0x5S9ez5U
Good Luck!
Posted on Jan 13, 2011
My onkyo reciever HT-R758 stopped working no sound . i have checked my speakers with other reciever and they are fine
If you are getting display screen properly after power on, try to factory reset the device (Check the user's manual provided with the unit)
Jan 02, 2017 | Onkyo Audio Players & Recorders
Reciever slow to turn on volume
Hello Cindi, If the audio does not come on for a short period of time this usually indicates that there is an issue with the audio relay. To try to fix this, I would suggest a reset of the unit. After resetting I would also take another step of doing a power cycle. To do this you will unplug the unit from the wall for about 10-15 minutes to draw out all of the stale power in it. If these two steps do not address the issue then the receiver would have to go in for service. Thanks, FJD
Feb 16, 2016 | Onkyo HT-R590 Receiver
My onkyo HT-HT-R590 not working properly. . only indicates lights hdmi thru and green light hdmi
Hi Madhu, I am a bit confused with your questions. If this has not been resolved for you please give us a call at 800-229-1687 as our Product Support Team is ready to assist 24/7, Thanks, JT
Apr 20, 2015 | Onkyo Audio Players & Recorders
My onkyo ht-r590 goes on then shuts off right away.
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Oct 01, 2014 | Onkyo HT-R590 7.1-Channel 3-D Ready Home...
Onkyo TXNR-609 intermittently turning itself off
Hi, there is no need for entering any serial numbers for factory reset. For hard reset press and hold VCR/DVR botton then press ON/STANDBY,secound later on the display should say CLEAR . So now you receiver is back to factory settings. If that works great if not try Firmware update for your model ,and if that failes
try unpluging all your speakers ,and try connecting your USB,CAB/STA or what ever you want(speakers unplaged). Btw dont forget trying different cabels. Last if all dont help you should contact ONKYO Servise/dealship.Hope ti helped you with your problem .
Jul 23, 2014 | Onkyo TX-NR609
Remote will no longer power on Onkyo HT-S3500. Once I turn it on manually, the rest of the functions work properly.
I just had this same issue. I tried to change the batteries for the factory remote that came with the Onkyo HT-S3500 (remote: RC-799M). Still no luck. It would not power on with the remote, despite the light flashing and the and all other remote function working. If I powered on the receiver manually, everything worked (except power on/off).
I just pushed a button on the remote labeled "REMOTE MODE RECEIVER" and viola, the remote now powers the device on and off and works just like usual. Not sure what the heck happened, but I would suggest pushing that button on your remote.
Dec 19, 2012 | Onkyo HT-S3500
Onkyo ht-r590
I hear all speakers except back ones I took them off in hooked in dif. Spot in heard sound so speakers work ..I went to setup in listen to all speakers no sound from the back
Nov 21, 2011 | Onkyo Audio Players & Recorders
Onkyo HT-R520 no sound
i did a factory reset on mine. it had the classic problems. no sound from any input except the tape input. after i did a factory reset they all seem to work.. we shall see for how long...
Jan 20, 2010 | Onkyo HT-SR700 System
Onkyo ht-s5100 lost sound
Double check that the approtiate speakers (A or B ) are selected.
Jul 10, 2009 | Onkyo HT-S5100 Theater System
Onkyo HT-R520
Hello the HT-R520 is the model of the receiver that is part of the HT-S770 package. I suggest that you check the speaker settings. Check the level of the center speaker. If you need assistance please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Jul 02, 2017 | Onkyo HT-SR700 System
61 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
