Question about Clothing Accessories
SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
Posted on Nov 21, 2007
SOURCE: Kenneth Cole KC1104 wristwatch
You can contact Kenneth Cole in the address below:
Kenneth Cole Geneva Watch Co Inc
47-50 33rd
Long Island City, NY 11101
Phone: (718) 729-8600
Fax: (718) 729-8761
They will direct you to their parts department.
Goodluck..
Posted on Apr 05, 2008
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
SOURCE: How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Posted on Dec 20, 2008
Jan 09, 2015 | Kenneth Cole Watches
Apr 05, 2008 | Kenneth Cole KC1104 Wrist Watch
Oct 13, 2014 | Kenneth Cole KC1296 Watch
Jun 24, 2013 | Kenneth Cole Watches
Jun 21, 2011 | Kenneth Cole - Ladies Watches - RK4087
Feb 06, 2009 | Kenneth Cole RK5034 REACTION
Feb 05, 2009 | Kenneth Cole KC1104 Wrist Watch
Oct 18, 2008 | Kenneth Cole 1213 Wrist Watch
Jul 13, 2008 | Kenneth Cole KC1104 Wrist Watch
Oct 27, 2007 | Kenneth Cole KC1104 Wrist Watch
324 people viewed this question
