Hi m tariq amin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Hi m tariq amin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
The priming option should be in the service menu. Typically you start the priming operation and the plotter will prompt you to install the startup heads (orange). Make sure you have no low cartridges or the operation might fail, although I believe the system will tell you if any ink tanks are too low to prime.
Hello. Designjet T1100 disk failures are pretty common. HP has made it difficult to do anything with their HDDs by securing them with passwords. When a new HDD is installed, it also takes on the ID of the plotter and refuses to work in any other plotter from then on. LPS Computer has T1100 hard disk drives that have been modified to install and work properly and they cost less than HP is asking. They can be seen here: http://www.lpscomputer.com/collections/designjet-t1100-t1120-parts
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
The most common cause I've seen is that when people put the new cartridge, they forget to remove the seal which makes the ink stay in the cartridge. It is typically a strip that covers the hole where the ink comes out, or else a strip that is located far from the hole, but that needs to get removed or else the ink will not flow from the cartridge
Tech guys only: Service station error..Remove right cover, remove & take out service station, check any objects in service station movement, remove motor clean entire unit with water you can find out lot of ink inside & too dirty clean it allow to dry apply grease for smooth movement( pl take care of pumping unit & tubes), fix it back, perform service station test ( to enter in service mode switch of the machine with power off button from front panel hold UP arrow button & OK key button then which on the from front panel button, wait till enter in service mode scroll to service station enter, three options service station,primary motor and aerosol motor select service station, enter wait till result papers on panel) best of luck...
I have this error with my Designjet T1110. I followed the instructions in the service manual 2-14 for troubleshooting. questions: - instructions say :"Check that the Starwheel Assembly cable is not damaged and is correctly connected to Main PCA." but I could not locate any cable from the starwheel assembly to the main PCA. I could see only cable from the starwheel motor assembly to the main PCA.
Star Wheel Motor has a problem. 01 code says "reseat/reconnect/clean and manually adjust" the motor. The Star Wheel Motor is on the left side of the printer. If you arn't trained on it, get someone who is, to service it.
For a single computer you can install a JetDirect card and assign an IP address. Then connect the computer to the plotter directly through the ethernet connection on the computer using a cross-over cable (standard ethernet cable will not work unless you use a hub). Another option is to simply use a USB cable connection. Drivers are available from HP.com, Support, Downloads.
