If you had rolled it through some kind of petroleum based solvent like acetone, gasoline, kerosene, benzene, diesel fuel or, sometimes, alcohol, you may have converted the rubber tires into something akin to bubblegum. If you turn it upside down and feel them, check to see if they are sticky or gooey. If so, you'll have to replace them. Good luck.
SOURCE: DC15 - scratching wooden floor
You should have an adjustment to remedy this...it is usually called a pile adjustment and is often found in the area above the beater bar.
Is the bar worn? Is there something in the bar causing the scratches?
SOURCE: Hardwood floor cleaner
Yes, you can use the Bruce hardwood floor cleaner. I've used it many times to clean up after jobs. It brings a nice shine to the floor and is designed for either a hardwood or laminate floor. Hope this helps.
SOURCE: When I turn on mt dyson is sounds normal. once I
With the DC14 in its upright position, and looking from the back, there is an access hatch just to the right and bottom of the dust canister. Remove this and check for any obstruction. With the hatch still removed, tilt the handle back (as if vacuuming a floor), and you should spot that the mechanism in to which the access hatch fits changes over from one hole to another. This is how suction is transfreered from the telescopic arm to the brush bar when the unit is taken out of the upright position.
With the handle tilted back, the hole you can see is one end of a flexible pipe that leads to the brush bar. Check for any blockage and/or foriegn objects. If there is no obvious problem, you'll need to check the other end of the pipe. You can do this by removing the toe plate on the bottom of the brush bar area. The plate is held by 3 or 4 half turn fasterners - a 5 pence piece is ideal for undoing these.
If still no joy, the only other thing it might be is that the brush bar isnt spinning - this isnt actually lack of suction, but without brush rotation any upright hoover is far less effieicnt at picking up bits from the floor. Brushes not spinning on a DC14 is quiet a difficult thing to fix on a DC14 as there are two separate rubber belts, one of which is hidden under a plastic cover. There is also a clutch mechanism between the belts that can cause problems some times.
SOURCE: washer shakes terribly in spin cycle
Does the floor or the walls shake? If they do you have to beef up the flooring under your washer, with blocks between the floor joists, piers, or sistering of the joists. If there is no shaking of the floor or walls, and your washer is solid on the ground, leveled and not rocking, then it is your washer. Lg has problems with too much vibration in their washers. Check to make sure that your lint filter/coin catcher is clean. Open the door in the bottom front, put a towel down to catch the water, Unplug the washer, and unscrew the large plastic screw that is the filter for your washer. If this has debris in it clean it out completely. Look in the hoses also, if your water drain is restricted by lint or coins or other debris, the washer has clothes in it that are wetter and heavier than they should be, and this will cause sever vibration. Good Luck, Appliance Specialists
SOURCE: My Dyson will not vacuum
Sorry to hear you're having difficulties using your DC24 on this particular rug. You may find the cleaner's powerful suction causes certain lightweight rugs to seal closely with the soleplate, requiring a little more effort to push.
Reassuringly, it sounds as if your cleaner is performing correctly, but if you have any further concerns about this issue, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need.
Kind regards,
Jack
Dyson Online Customer Support
