Question about Pyramid Car Audio & Video
Wiring diagram for a pyramid 719A 7 band eq - Pyramid Car Audio & Video
Posted by pretty boy on
Tom Chichester
    Top Expert:
  • Pyramid Master
  • 55,379 Answers
Request the diagram directly from Pyramid.
Posted on Dec 31, 2018
5 Related Answers
Anonymous
  • 31 Answers
SOURCE: need to find wiring diagram for a sony TA-AX 295 home amplifyer/eq
Hi *****, Try these URL's good Luck. YUBEUT http://www.eserviceinfo.com/ www.hisierrahifi.com
Posted on Dec 11, 2007
Anonymous
SOURCE: wiring a pyramid 903G
red - power
Black - Ground
Blue/Black - rear Left Speaker Positive
Blue - Rear Left Speaker Neg
White/ Black - Front Left Speaker Positive
White - Front Left Speaker Neg
Brown/Black - Rear Right Speaker Positive
Brown - Rear Right Speaker Neg
Yellow/Black - Front Right Speaker Positive
Yellow - Front Right Speaker neg
Green - Left Input Positive
Green/White Left input Neg
Gray Right Input Positive
Gray/White - Right input Neg
Posted on Jan 02, 2009
ronaldo_ross
Ronado Panaligan
  • 1056 Answers
SOURCE: how to install a 7 band boss eq with no high input
If you are using the low input to put high input in you can use a 22k resistor and a 10uf capacitor connected in series to the plus side of the speaker wires. This will bring down the signal level from the speaker to low input level and you will have a nice distorted free music.
Posted on Aug 11, 2009
Anonymous
  • 14 Answers
SOURCE: EQ settings
This setting is a blast,I adapted it from the 10 band "perfect" itunes eq setting. don' t be shy , give it a try...
80hz = (2) or 7
220hz = (0) or 5
470hz = (-1) or 4
1khz = -(-2) or 3
2.2khz= (0) or 5
4.7khz =(2) or 7
12khz= (4) or 9
I have this on my LG tv, however if you need more oomph! to it, simply stick to the same pattern between the two sets above and move each slider up accordingly.
Posted on Jun 15, 2010
key420
SOURCE: color code for speaker out on a JVC KS R140 car casette player
White - left front
Grey - right front
Green - left rear
Purple - right rear
Yellow - memory power
Blue - remote power (power ant, amp or eq power)
Posted on Dec 15, 2010
Pyramid SE405-VL-LED
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Feb 12, 2013 | Pyramid 7 BAND EQ W CD INPUT Car Equalizer
Contact a local car audio professional or Pyramid customer support directly here:
Need wire color codes
Feb 22, 2012 | Pyramid 719A 7-Band Car Equalizer
Not sure of the best setting for the best sound and bass
Equalizing audio is truly a matter of preference and depends largely on the song you are listening to. You can try this guide to get the best sound for you.
Feb 28, 2011 | Pyramid 719A 7-Band Car Equalizer
NEED WIRING DIAGRAM FOR PYRAMID SE705-VL-LED CAR EQUALISER
Aug 07, 2010 | Pyramid 7 BAND EQ W CD INPUT Car Equalizer
I need to know how to wire up a pyramid 403G eq/amp
Try this; Recommend contacting a local car audio professional or Pyramid customer support directly here:
Jul 31, 2010 | Pyramid 403G 7-Band Car Equalizer
Need help
not worth the effort
Mar 17, 2010 | Pyramid 719A 7-Band Car Equalizer
Help
red -power
black/casing - negative(ground)
orange-is memory/ignition on
the rest are right'left outputs
Sep 19, 2008 | Pyramid 403G 7-Band Car Equalizer
Car Audio & Video Logo
76 people viewed this question
Top Pyramid Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Alphanso Tee
Thomas Perkins
Thomas Perkins
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
