Question about Mad Catz Radio Communications
My mad Catz controller will blink but will not pair with PS3
Posted by Matthew vigen on
3 Related Answers
Anonymous
  • 716 Answers
SOURCE: mad catz gamepad for ps3 wont work..help
On Most Models They Will Work When You Hit The Reset Button On The Bottom Of The Receiver.
Posted on Feb 04, 2009
Anonymous
  • 10 Answers
SOURCE: My mad catz black ops
Try charging it first.
Posted on Dec 27, 2010
Anonymous
SOURCE: Mad catz controller blinks but won't connect
Go to Settings then System Settings then System Information. Once there check the "Version" of the System Software. If it's over 3.5 your "third party" controller is no longer supported. i.e. it will no longer work. Sorry, same issue here. :-(
My mad catz controller will not configure to my ps3.How can i do it wireless?
sir good day there are two way on how to configure your wireless controller to your ps3 console.... the automatic pairing and a manual pairing
first way an automatic pairing
1.turn on your ps3..
2.Connect the smaller end of the included USB cable to the PS3 controller.
3.Connect the opposite end into either USB port on the front of the PS3.
The pair light on the PS3 will flash. When it stabilizes, you can disconnect the USB cable
and use the controller wirelessly.
second way a manual pairing
1.. turn your ps3..
3.Connect the opposite end into either USB port on the front of the PS3. Press the "PS" button on the center of the PS3 controller. The pair light on the controller will flash. When it stabilizes, you can disconnect the USB cable and use the controller wirelessly.
you can try that 2 way on how to configure your controller to your ps3 console if this help you please rate me thank you sir..
1helpful
How do I get my mad catz call of duty blk ops controller to sync to my ps2 when I try 4 lights just blink across the controller with or without the han cable
This particular controller is not for the PS2 thats why you can't connect it. The control is only meant to be used on the PS3.
Why wont my mad catz headset connect to my ps3. The PS3 gives me this error message 80010009.
Try to delete the headset from your bluettoth devices list on the PS3. Turn off the PS3 and then back on. Re-Pair your headset and see if you have the same error.
Hope it helps...
1helpful
My wireless mad catz controller wont connect. the usb reciever light is solid but the controller lights just blink
Mad Catz has been known to cause hardware problems with Sony units. However, it sounds like you are just having a sync problem. Try plugging in a USB Cable to the PS3, connecting it to the controller, then pressing the Home button.
14helpful
2answers
2helpful
I have a mad catz head set for my ps3 and it's showing up on the ps3 but i cant talk to anyone.whats wrong?
The headset wouldn't connect so we deleted it. Then went back and tried to pair it again. And it wont flash blue and red, just blue.
What is the code to set your hed set up on the ps3 for the mad catz hed set
Pairing code is 0000 (four zeros).
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
4helpful
I can not get my mad catz bluetooth connected to my ps3.... I also do not have the instructions but i do have the pass code
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
Hope this helped.
Mad catz gamepad for ps3 wont work..help
6helpful
2answers
Radio Communications Logo
Top Mad Catz Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
