If you have problems feeding paper, try these solutions:
·Make sure the paper cassette is inserted in a proper way.
·Check the paper size and type settings properly you loaded.
·If paper does not feed correctly, remove and reload it in the cassette and adjust the edge guides. Make sure the paper stack is not above the tab on the edge guides inside the cassette.
·If multiple pages feed at once, remove the paper, fan the edges to separate the sheets, and reload it.
·Do not load more than the recommended number of sheets.
·Make sure your paper meets the specifications for your product.
·If paper jams when you print on both sides of the paper, try loading fewer sheets.
·If too many pages are fed when you are performing manual 2-sided printing, remove all other paper from the cassette before reloading the paper.
I hope your problem will be resolved. If you need any help, you can directly contact Epson printer experts through
Free Live Chat.
