Question about Karcher Garden
Karcher 2 motor won’t come on. It’s plugged in and switched on. It works fine the other day.
Posted by Steve Lentin on
2 Related Answers
Bruce Robin
  • 299 Answers
SOURCE: Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Posted on Apr 16, 2010
Testimonial: "Thanks brobin, your advice was spot on and it is now working again, much appreciated"
Tuckerbag
  • 4 Answers
SOURCE: I have a Karcher K5.55M The motor pulses and only 1/2 pressure
In the video link above, at 7 minutes,.. through to 7 minutes 8 seconds,.. the guy talks about a "minute crack in the cylinder head". He actually means to say "minute crack in the control head". This minute crack is the main reason for this common problem: the pulsating and some loss in pressure on a wide range of Karcher waterblasters.
I got a replacement control head from my local Karcher dealer for NZ$50 that fixed the problem,.. for now :-( The below picture has two red ovals around the cracks in the control head that are very hard to see. If Karcher made this control head from an aluminium casting, their product range would be a LOT better. eade87d9-b4d8-4625-bd50-c466405ff2e3.jpg
Posted on Oct 20, 2014
Karcher k3-91m electrical box
There is a strong possibility of a defective switch.
Aug 12, 2016 | Karcher Garden
Hi, My karcher 5.86 has suddenly stopped working. No power/ noise from washer when power is switched on. Fuse & source is obviously fine. Im going to obtain relevant torx screwdriver this week to open...
If its not the fuse in the plug it might be the on/off switch. I would check switch for continuity with a multimeter to rule it out first.
Feb 01, 2015 | Karcher Garden
My karcher pressure did turn on but stopped working altogether now wont turn on
Make sure that your circuit breaker did not go off and you have power..
Turn on the water after connecting the hoses. Then connect an ohm meter to the hot and ground legs of the male power plug. Push the on/off button to on and then pull the trigger. When you do that your ohm meter should indicate the resistance of the motor windings. If the resistance still stays at zero, then 1 - your motor is burnt out, 2 - the on/off switch is not working, 3 - the water pressure switch is electrically open. Check all three for proper operation and replace as needed.
Apr 01, 2014 | Karcher Garden
New k 3.190, motor does not work
So I just read this very helpful posting.
I dismantled my Karcher 3.190 plugged in the hose and spotted a leak coming from the inside on part of the casing?. When I switched on the pump, it started gushing. It's just out of warranty!
Do I,
A: junk it and slam Kirchner via social media or is it
B; fixable at a reasonable cost.
Opinions, witty replies, and solutions always welcome.
Regards
Wil
Mar 17, 2013 | Karcher Garden
Karcher K2.36 Pressure Washer I've just fired up my Karcher for the first time since last year and the motor started running fine, I then switched on the tap to allow the water through and the motor cut...
The water must be switched on, and seen to be running freely from the nozzle for a few seconds before switching on the power - suggest you check the fuse in the plug, and then try the above.
Apr 17, 2010 | Karcher K2.26 Electric Power Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Karcher B402 pressure washer Motor runs as soon as power supply connected, on/off switch does not seem to make a difference and no pressure at outlet? Was working fine, stopped for half an hour, came back...
bob I had this happen to my Karcher, the pressure seals have blown. $Au200 for service and replacement from karcher dealer. tyhey would not sell the parts for a DFY
Jun 22, 2009 | Garden
Karcher Press & Ex 800
The water pump is not working or the pump line is blocked. Check the pupm hose, if ok replace water pump
Oct 09, 2008 | Karcher K DS 5500 Vacuum
Garden Logo
56 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
