Question about Motorola Televison & Video
I need codes to connect a One-For-All uRC-3300B01 to a Spectrum Motorola Cable Box
Posted by David on
5 Related Answers
Anonymous
  • 129 Answers
SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
dscollard
SOURCE: Remote Control Code for Motorola Cable Box
I have a Motorola cable box and used code # 051. Works great. Can't find a code for DIGISTAR tv though. If anyone has one, shoot it to me at [email protected]
Posted on Jun 15, 2008
Anonymous
  • 6 Answers
SOURCE: can't find code
try this: www.urcsupport.com
Posted on Dec 22, 2008
Anonymous
SOURCE: Emerson Jumbo Remote Code for Motorola Cable Box Needed!!!
I just used 051 with the giant emerson remote and a motorola cable box. It worked right away. Good luck.
Posted on Dec 28, 2008
Anonymous
SOURCE: Unicersal Remote code for Motorola cable box
I found this on another site: It works BUT you don't have all the functionality you would have with the cable remote (of course). If you want power on/off, vol up/down and channel change.. this is your fix.
Was this comment useful?
new Starbox("rating1496612", 0.0, {identity: 1496612, stars: 5, buttons: 5, max: 5, total: 0, onRate: saveVote});
  • Motorolla Comcast code Posted by whowlett5 on Dec 26th, 2008 at 12:40pm
    I got mine to work using the Code search method. The manual is incorrect though about using the code search: Instead of pressing Power repeatedly, you just press it once. It sequences through the codes. You then need to press Enter immediately when the comcast unit turns off.
  • Posted on Jan 14, 2009
    Is it possible to download Spectrum Cable App to my Vizio D43fx-F4 Smart Tv? Also, is it possible to connect two televisions with just one Spectrum cable box?
    To run more than one TV from your cable box you need a splitter connector to split the output from the cable box to the two TV's.
    I want to program my one for all remote (model 3021) to my Motorola digital cable box do you have the code?
    Motorola Cable box codes 0476 0810 0276 . I hope one of these helps. Unfortunately, if your cable box is newer than your remote or was released less than 6 months before the remote was programmed, the code you need may not be included. There is a bit of a time lag for releasing the codes to the makers of universal remotes. For more information and the code list try here: http://oneforall-na.com/remote.php?type=URC%203021 .
    I hope this helps.
    When I purchased the remote the wrong set up manual was enclosed!! This is the one for all big esay remote, URC-3300B01 need code for older phillips TV.
    Go to the remote's manufacturers website and look for the support section.
    Most of the manufacturers have a section there with manuals in it..
    1helpful
    Remote Codes for Motorola Cable Box DCT700/US
    I have run into this problem with my Sharp Aquos as well. This is not necessarily a code problem but an interference problem.
    If you take your hand or a thick book and sort of make a hood over the area of the sensor on the cable box and place the remote right up close to the sensor this will help let you know if the remote and the box are working with the code. Also might try turning off the TV or unplug the TV to test and make sure the remote will turn on the box.
    Next thing after you determine this is how to block the interference and be able to use your remote. What we did is placed the Wii on top of the box over the area of the sensor and this seems to have done pretty good.
    Good Luck ....
    1helpful
    MY TIME WARNER MOTOROLA DIGITAL CABLE BOX CODES
    There is only one code listed for Motorola cable box's, 1376.
    If it doesn't work then your going to have to use the search through the internal memory of the remote. Below is a link to a web page of your remotes manual. Look under "Searching For Your Code" for the steps to do this. It's in .pdf format so you'll need Acrobat Reader if you don't already have it to view it.
    Hope this helps.
    http://www.oneforall.com/uploads/support/a75c4c2d67fdf305e4a8497cb64b60d0.pdf
    2answers
    I have URC-5741B00 and need to get the code for a Panasonic 27" TV and my Motorola Moxi Cable box. It might be too old for these codes.
    for the tv these codes might work..
    0171, 0170, 0148, 0054, 0062, 0374, 0381, 0437, 0950, 0003, 0070.
    Hopefully this will help
    2helpful
    2answers
    Universal remote code needed for motorola cable box (for comcast)
    Many thanks
    Mark
    (www.sparky-uk.com)
    Televison & Video Logo
    Top Motorola Televison & Video Experts
    Joaquim Martins
    ray gallant
    Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
