Question about Frigidaire Freezers
Frigidare Standup freezer 20.3 model GLFH21F8HWD Problems. I have it set to -18 and when I open door the lite comes on then turns off and on then the temp goes to -19 and the motor kicks in.
It started with opening the door and the lite would go off and the screen would read -1 and keypad would do nothing. It would kick in on its own and start working again. I unplugged it for a few days but still acting up. Can someone help??
Posted by Rod Hoyseth on
5 Related Answers
Anonymous
  • 87 Answers
SOURCE: refrigeration problem
It sounds very much like control board problem. The chances of both sensors at fault seems unlikely. Unusual that it is the exact same temp unless they are your setpoint requirements. I would advice contacting reliable fridge guy to check the cabinet. Hope this is of some if not much help.
Posted on Sep 15, 2007
Jose Ramirez
  • 263 Answers
SOURCE: FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Posted on Dec 29, 2007
dcp2
Daniel Phillips
  • 63 Answers
Sounds like a main board problem cause the temp should not be accurate one minute, then way off the next. I would have someone look at this cause it would be difficult to figure this out without being there to troubleshoot it
Posted on Jan 28, 2008
Anonymous
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: running long time
hi thanks for the question. yes if that's the temp that you say 36 to 38 degrees is normal operating temp thanks the appliance doc
Posted on Sep 24, 2008
Frigidare chest freezer model cf-8h-L compressor is running but not getting cold on the inside
Recycle it. It is on R12 which we haven't used for 20 years. If the compressor has gone, or if you have lost all the gas, it is beyond economic repair.
Jul 13, 2015 | Freezers
We have a Kenmore 16, model model 253.8283680, that recently continuously cycles on and off. What could be the problem associated with this?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The normal cycle is: Your compressor will turn on to raise the freezer temperature 20 degrees F. above the set temperature, and then the compressor will shut off, Until the freezer temperature drops 20 degrees F. below the set temperature and again the compressor will turn on.
One of the main problems with this type of freezer is the door gasket becomes crushed over time or the door is so thin it becomes deformed.
Do not try to replace the door gasket. You have to soak the new gasket in hot water for 1/2 hour and then form it on the door.
If you notice a gap in the corner of the door - pull hard on it to get it flush.
Recondition the door gasket - With a hair dryer and a kitchen spatula, heat the gasket and try to expand the gasket by pulling out with the spatula.
You can purchase a special freezer lubricant. Be sure not to over do it. It can make the door hard to open. P/N 542638
1/2 Oz. $12.00.
Mar 19, 2015 | Kenmore Freezers
Light flickers when door is opened
it has connection problems when you open the door of freezer connecting wire turn gradually and one time comes up light normally,you repair connecting wire of lights.
Mar 23, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Hello I have a frigidare upright freezer i want
You can't....most freezers have set position so air can rotate evenly for a reason.
Jul 15, 2010 | Freezers
Correct suction line pressure
If it is R22 then it will be about 11psig on the suction side. This should give you a -18 degrees across the coil.
Jun 30, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Temp control flashing E 9
Look online and see if you can find an installer's manual. Sounds like the control board hasn't been set to your model yet.
Mar 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Jan 04, 2009 | Freezers
Freezers Logo
295 people viewed this question
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
