Question about Danby Dishwashers
Error code ER1 on a Danby countertop dishwasher model DDW611WLED
Posted by Ray Christie on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Danby countertop dishwasher
Very important only use half teaspoon of soap. To much soap can cause it to leak. Also only use dishwasher soap.
Posted on Feb 03, 2008
Anonymous
SOURCE: my danby countertop dishwasher won't drain
the problem has not been resolved. does not drain.
Posted on Jan 18, 2009
Anonymous
SOURCE: E3 code
Received from Danby customer support:
"The error code of E3 tells us that the unit is not getting the proper water temperature to continue thru the entire cycle. Before starting the dishwasher and attaching the quick connect assembly to the faucet, please make sure that the water from the faucet is warm to the touch; you can then attach the quick connect assembly with hose to the faucet and start the unit. If the water temperature does not reach 120 degrees F the dishwasher will not be able to run thru the entire cycle properly. If this is being done and the same code comes up, we will need a service tech in you area to diagnose the problem for us. For a warranty servicer in your area you can reach us at 800-263-2629 Mon-Thu 8:30-5 or Fri 8:30-4 EST."
Posted on Feb 04, 2009
Anonymous
  • 15 Answers
SOURCE: danby countertop dishwasher model:ddw396w. doesnot
change the pump
Posted on Jun 05, 2009
Anonymous
  • 3 Answers
SOURCE: how do we get the danby countertop dishwasher
Danby customer service told me that was a feature built into the program.
Posted on Jan 21, 2010
Danby dishwasher faucet adapter
Yes, I have a new portable dishwasher and no adapter, not sure what size to get. model DDW1899WP-1
Jun 25, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Electrolux dishwasher giving error code 1?
Good Morning Brian,
I understand that you are receiving an error code 1 on your Electrolux dishwasher, model# EWDW6505GS. Error 1 is stating that water has been detected underneath the tub. Check underneath your dishwasher by taking off the kick plate below the door. If you do not notice any water underneath the tub or any types of leaking, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker for 20-30 minutes. When the time has passed, restore power, and run any cycle. If you are still receiving error code 1, I suggest you contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 07, 2014 | Electrolux EWDW6505GS Fully Integrated...
My Beko DW686 Dishwasher displays ER1 Error Code, there are no error codes in the manual, can you help?
reset error code 01. pulled dishwasher out removed kick plate tipped at 45 deg angle and found no leaks or water. turn6ff59c77-7c20-45c4-ac2a-e3c9e6fd4c14.gif breaker off and back on after 20 minutes still doesn't clear.
see tje diagram attached. God bless you
May 25, 2013 | Dishwashers
What does an E3 code mean?
hello,
what this mean is an indication of a problem detected b the sensor
Some models of washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
thanks
Oct 23, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
What does E3 mean?
E3 not hot enough. This defect can be caused by, but not only, a defective element or clogged spray arms.
Sep 29, 2017 | Dishwashers
I have a Danby DDW399 W countertop dishwasher
I have a Danby DDW399W countertop dishwasher. I need a replacement tap attachment and haven't been able to locate one. Email [email protected]
Jan 14, 2008 | Danby 22 in. DDW396 Free-standing...
i would think the drain hose from the unit is leaking from the description you give.let me know
Dec 24, 2007 | Danby 22 in. DDW396 Free-standing...
Dishwashers Logo
128 people viewed this question
Top Danby Dishwashers Experts
Michael Thomas
Michael Thomas
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
