Question about Bryant Heating & Cooling
Manual for Bryant model 396GAD036075 - Bryant Heating & Cooling
Posted by Lloyd E Fountain on
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
Bryant 398AAZ MANUAL
Link below for the Bryant 398AAZ manual.
Bryant 398AAZ Manual
Bryant model 394GAD manual
The manual can be downloaded here: http://www.bobsmanuals.com/Household/Heating_and_Air_Conditioner/Bryant/394GAD/manual/
Manual bryant model 394GAD
Here's a link to the manual, as requested.
Bryant 394GAD Manual
Manual for model no. 234c 5pw bryant boiler
I have a bryant boiler in my home and been having a plumbing co work on it since spring and they replaced the 3 speed pump with a single speed now cant get it to push air out of system
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Heating & Cooling Logo
Top Bryant Heating & Cooling Experts
Dan Webster
Dan Webster
john h
Tom Chichester
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
