Computers & Internet Logo
Question about CIPHERLAB Computers & Internet
Cipherlab 8001 enter expiration date produced by the keyboard during goods entry
Posted by laterra74 on
2 Related Answers
Anonymous
  • 52 Answers
SOURCE: Faut-il installer un driver avant
FIXYA ADMIN CHECK. Q APPROVED.
Posted on Jan 15, 2011
Mustgo
Vincent G
  • 2363 Answers
SOURCE: i have a Cipherlab scanner 8001, when i connect it
OK,you indicated COM1 serial port is working on the a Cipher scanner 711.
Please check the communication setting on the Cipher scanner 711.
The most popular setting are
AUTO BAUD RATE
or
9600 bps 8 bits N for no parity check and 1 for check bit.
Short for as
9600 8 N 1
Check the setting on the Cipher scanner 711 communication speed and make set the Cipherlab scanner 8001 to the same rate.
MAKE SURE YOU RE-BOOT the Cipherlab scanner 8001 before re-try.
Please keep me up to date on the fix via email.
Posted on Jan 30, 2011
1helpful
2answers
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
How do I get the craddle to turn on
It depend of model of your cradle:
If cradle is without charge capability (suits CPT-8000), it get power from USB for internal logic and irda.
Cradles with charging capability ( two charging pin in cradle socket) need a powersupply to power both the charging of CTP-8001 and the internal logic/irda.
The driver need to be installed before connect the cradle to computers USB-port.
Wellsfargo com login
Really ??
You have to supply and expiration date to use it.
The one with the date that is approaching in about 13 days is your old one.
The one with the expiration date that's a couple years later is your new one.
But, you won't see this because your keyboard either failed or you passed out face first on it at the end, there...
Acer laptop problems with typeing
First thing try swapping out your keyboard with another; if problem stops you possibly have dirt in the keyboard-needs cleaning or possibly replacement. If problem does not stop and your keyboard is USB try a different USB port to plug in to. If problem still does not stop try a system restore back to a date before this started. If that does not help, try entering safe mode. If problem stops something is loading that is conflicting with the mouse. Enter MSconfig and disable all load entries, reboot and see if problem stops. If it does, enable each entry 1X1 until problem starts again and you found the problem. That should get you started.
1helpful
I have a Cipherlab scanner 8001, when i connect it to a linux computer, it doesnt download it gives me a Time out error, but when i connect a Cipher scanner 711 to the same COM port it works. Please advice...
AUTO BAUD RATE
or
Short for as
9600 8 N 1
2helpful
Hello! I have a problem when programing the CipherLab 8001-C Application Program (AG8000N.exe). The download start (terminal bip) and after 3-4 sec show "Download Complete" but the terminal show the...
Cipherlab has technical support available - I'd recommend getting in touch with them. The Cipherlab global site is: http://www.cipherlab.com/default.asp - you can choose your region, then support or the contact link.
Some keys giving double letters cant enter password for windows
Good morning! possible that some of the keys (/letters) terminal point of your keyboard were locked/stucked-up during your cleaning. I suggest to use another keyboard then check the status of the keyboard if it is working properly thru Device Manager. best regards
Keyboard data entry
Sounds like a classic problem for a driver/firmware update. get an update here before trying anything else- http://www.palm.com/us/support/downloads/tungstenc/tungstenc_update_30.html If it still doesn't solve it you might need to format it and reinstall everything from scratch. Good luck
Top CIPHERLAB Computers & Internet Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Larry Ng
Larry Ng
Are you a CIPHERLAB Computer and Internet Expert? Answer questions, earn points and help others
