Question about Radio Communications
How do i connect a headset to QIP7232 2 ?( wired or wireless)
How do I get rid of the static sound in my 4PR908?
There causes varies from types of headset to another. In respect of a wireless headset, the static sound is caused by interference. Whereas in a cord headset, a loose wire somewhere in your headset or cord is responsible for the static sound or crackle. It might also emanate from the mic in respect of a one calling, or from the ear-piece.
The solution with a wireless headset is to move away from any device e.g computer which might have cause the static sound. Resetting the wireless headset is also a solution measure.
In the case of a cord headset; Get the cord wiggled at the plug and at the headset; and then move the mic to locate the loose connection. Where the problem occurs, loop the wire, taping it down at the point. soldering the affected wire is best than taping.
Finally, if the static sound persist;which it should not after all the treatments; check on the volume of the device. Reduction of the device volume can go a long way to bringing the longed solution. Similar problem occured with my headset;and was solved via the same recommended possibility.
Jan 30, 2015 | Wireless Gear 4PR908 Bluetooth v2.0 EDR...
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
While i connect my wire less headset it ask passcode
1 Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200 headset. 2 Select Samsung WEP200. 3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK. 4 Enter the headset passkey or PIN, 0000.
Regards MaTi_FleSh
Jul 03, 2011 | Samsung WEP200 Wireless Headset
My Wireless Headset wont connect with my Wireless Guitar, the wireless guitar says it has a mic connected and making noise when it doesnt, tryed plugging a wired mic in and out of the guitar it shows there...
I do not understand what you are asking....why would you be using an xbox wireless headset for xbox 360 with a wireless guitar: It would seem to me by the definition the headset is made for xbox 360 unit and not some brand guitar.
Jun 14, 2011 | Microsoft Wireless Headset for Xbox 360
Just today, one of the headphone in my headset stopped working on one side, if i pill the wire down some or move it around, it works. how do i fix this?
It is a loose connection in that wire, if the problem is inside the earpiece, then you will take some effort to try and fix. Unless you are handy with soldering, unless it is an expensive set, likely cheaper to replace
May 24, 2010 | Computers & Internet
I have a blackberry 9000 (bold) and want to connect it to a usb headset so when i am working at my laptop i can talk at the same time!
Unfortunately, Blackberry phones do not support a USB headset, even though both can connect to your laptop. You would have to use either a bluetooth or wired headset plugged directly into the Blackberry itself.
Nov 08, 2009 | Panasonic BLUETOOTH HANDS FREE KIT...
Cant connect. What type of device is the Motorola h350?
Motorola H350 is a Bluetooth headset device. Free yourself from confining wires and immerse yourself in music with wireless Bluetooth stereo headphones! You can comfortably enjoy your favorite music without messing with annoying wires!
Jun 26, 2009 | Motorola Mobility Bluetooth Hands Free...
I have a 93 Honda Goldwing with a built in CB Radio. I have a full face helmet that I bought with a bluetooth wireless headset that connects wirelessly to my cell phone. I'd like to be able to also connect...
the dongle is just the wiring to connect a wired headset to your jack on the bike there are many aftermarket companies who have the right parts to connect your headset to your stereo and cb radio I have j&m and they work flawlessly
May 08, 2009 | 1993 Honda GL 1500 Aspencade Gold Wing
Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Oct 28, 2008 | Jabra T5330 Wireless Headset
Radio Communications Logo
127 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
