SOURCE: Copystar 2221, C30 code
Hello sir; I believe your error code should be C030, if that's correct that 's mean main board is bad , it not worthy to repaire it, go buy a new machine.
SOURCE: Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
SOURCE: My Canon MP980 is showing Printer Error code 6000....
error [6000] or light blinking 3 times is mean there is an error occurred in the LF encoder signal.
SOURCE: How can I fix an error code 'c01-563' on Riso RZ370
Changing the ink tube or the RFID chip on the ink tube may solve your problem.
PrntNow.com
