SOURCE: low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
SOURCE: Replacing spring in wheel height adjustment
I just solved the problem. Go to this website: http://www.completevac.com/kirby_schemo_5.html
It will show you where the spring goes (left side inside the ratchet - when you remove the ratchet you will see that it is hollow. That's where the spring goes!) and a good picture of that assembly
SOURCE: spring connecting height adjustment
There should be a place easily for the wheel assy to fit back in and then if you look you should see 2 small holes in the bottom of the vacuum that it will slip into. If your looking at the vacuum straight they should be on the left side on the bottom.
SOURCE: Eureka Upright Vacuum 4230 Series. Spring popped
sure would like to know that answer myself does anyone know how to put the spring back i am about to lose my ever loving mind
SOURCE: Changed belt on my eureka airspeed sweeper n since makes loud noise, really loud n vibrates
Sonja, Recheck belt installation, see if it is riding in proper groove or is twisted.
Press the helpful button and follow me on fixya for more tips and info.
