Question about Reddy Heating & Cooling
Reddy heater wont stay running. reset restarts but trips again. disassemble and clean filter? or replace nozzle?
Posted by steve gress on
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: 50K BTU Reddy Heater Trips Circuit Breaker
If the unit lights Check the photo cell this can be done with an ohm meter and good light. Should have continuity in light.
Posted on Mar 02, 2008
tbugger
Jerry Magee
  • 232 Answers
SOURCE: REDDY HEATER PRO 200 WILL NOT STAY ON WITH TOP COVER ON
The nozzle is either restricted or worn to a point that the cone shaped fuel pattern is no longer producing a FOG, but is now producing a SPRAY and is not producing combustion. By removing the top cover the aerodynamics changes and allows the cone to expand & atomize better.
All bets are off, though, if you haven't checked the pressure on the air pump. Setting the pump pressure is easy but critical, especially if your heater has a glowbar & control board. Instructions are at www.reddyparts.com .
Check your heater over thoroughly for the exact model of your heater. "Pro 200" only designates a style and not all parts interchange from one PRO 200 to the other.
Posted on Oct 21, 2008
tbugger
Jerry Magee
  • 232 Answers
SOURCE: reddy heater will not fire.
Your problem is most likely the lack of pressure from the air pump. Your pressure is extremely low. Pressure on a 100k heater should run 5psi. At 3psi there is not enough fuel and not enough air to atomize whats there. Bump the pressure up. If it won't come up, then you have an air leak. Test w/ soapy water. Keep your fingers clear of the fan!
Posted on Dec 04, 2008
mandm7537
Michael Chipman
SOURCE: RM115 Reddy Heater forced air heater problem
I had close to the same problem i drain the tank added new fuel still no diffrence so i removed the filter going to the tank pick up flushed out with brake clean it work fine for half a day . I knew then i was on the right track . I went to the local hardware store and bought a tune up kit that had the filter in it,I replaced the filter going to the tank pick up and it's been working fine even in cold weather. Fuel quality has a big part to play in it's abbility to burn in colder tempicures.
Posted on Jan 16, 2009
Anonymous
SOURCE: troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Posted on Jan 18, 2009
I have an older 30,000 BTU spark plug type kerosene Reddy Heater. My problem is this; The heater will run for an hour or so then shut off. It seems as though it needs to cool down before it will allow me...
http://www.reddyparts.com/FAQ_spark_plug_heater.htm
Try the link below. You can run down the list of checks and also get parts. You need to repalce the nozzle or clean it yearly. If it's older replace plug too. Check pump pressure.
Jan 10, 2011 | Reddy REDR40T Heater
Wont stay running, fires up then shuts down, has fuel and spark, what else could be the problem. The filters are clean, also
There is a flame sensor inside the case, remove the top half look directly below the nozzle assembly and there it should be. These get dirty so clean it with windex and soft terry cloth rag, there are yearly routines you get in to owning one of these things, and if you do them each year they are good heaters. Biggest enemy is dirt and corrosion be it fuel system or the safety and sensors. The filters both fuel and air are important for proper fuel distribution and mixture.
Dec 21, 2010 | Reddy Heater-30-55,000 BTU Variable
I have reddy htr 35 was running great,just stopped reset breaker lit right up then went out Pulled cover off fan and spark fine reset it lights right up can see the fuel atomizing flame starts...
Check your fuel lines and most models have a fuel filter in line. A few things come to mind one how old is the fuel? Check the screen in the nozzle assembly by removing nozzle it sits directly behind the nozzle, these corrode and affect fuel flow. While you have this tore down clean the fire-eye with windex and terry cloth rag, it may not be seeing the flame. Check the air filter at the back of the heater as well. These are common problems with these heaters.
Dec 13, 2010 | Reddy Heater-30-55,000 BTU Variable
I have a Reddy Heater 70,000BTU without a thermostat. It will flare off and within a few seconds the fire goes out and then the it trips out. After a few tries it won't even flare off. What might be wrong?
hello. Your reddy heater is dirty and needs a good cleaning. Also, here are a few other possible reasons why it won't operate properly. Pressure not adjusted to 5.1 psi, dirty outlet filter, clogged inlet filter, bad or dirty photo cell, defective reset switch, pump going bad, dirty injector nozzle, dirty fuel filter, contaminated fuel. Check yours out and do what you can to address each area of concern. Regards, Joe
Jan 21, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heater turns on for a few seconds then goes out
Absolutely K1 or diesel can get old in a hurry, the ultra-low Sulphur diesel has been tinkered with so much that it turns to book varnish much faster than before 2010. Most of those heaters spray fuel past the igniters using a siphon much like a spray paint gun, the suction tube may have dry rot or a small air leak and it it takes but a tiny air leak to kill the siphon effect. Check the tube from the nozzle all the way down to the fuel tank or replace it if you're not certain it is not compromised or dry rotted.
Oct 12, 2017 | Reddy Heater-30-55,000 BTU Variable
REDDY HEATER PRO 70
I have a Reddy Heater R100 that ran just fine until one day it
wouldn't ignite. I took the cover off to see if it was sparking and it
ran just fine with the cover off. I got on the Internet to see if there
was a definitive answer as to why it would only run with the cover off;
there wasn't. So I decided to troubleshoot it step by step instead of
replacing everything at once. You can thank me later.
Step 1: Dumped out old fuel, made sure the tank was completely dry and
clean. Put in fresh kerosene. This is an absolutely hideous job.
Result: Still would only burn with the cover off. Said bad words.
Step 2: Replaced all three filters. Result: Still would only burn with
the cover off. Didn't say bad words, just thought them.
Step 3: Removed the end filter cover and pushed on the pressure relief
ball. It seemed to be stuck.
so I marked the relief screw, counted the exact number of turns to take
it out, and washed the end filter cover and small parts with Dawn
dishwashing detergent. Harsh solvents can melt the plastic on the end
filter cover. Blew everthing dry. Put a little oil on the spring and
ball so they wouldn't rust. Put the relief screw, spring and ball
together, making sure I turned the screw back in the same number of
turns that I took it out with, within a tolerance of about 1/8 turn.
Step 3: Downloaded a manual from:
http://www.desatech.com/manuals.cgi?products=Construction%20Heaters to
find out the spark plug gap. They didn't have one for an R100 so I used
the one for a R100EDI. I cleaned and set the spark plug gap to .055".
I think later heaters use .075" or .085". Check your manual. Result:
Step 4: Removed the nozzle. Put a clean paper towel under the input and
sprayed carburetor cleaner into the output end of the nozzle,
backflushing it. Four or five pieces of crud came out, onto the paper
towel. Really cleaned the nozzle good. Blew it off with compressed air
to make sure all of the carburetor cleaner was evaporated. Replaced the
nozzle. Result: O frabjous day! It worked just fine for about a half
hour, then it started coughing and smoking.
Step 5: Removed the nozzle again. Put a clean paper towel under the
input and sprayed carburetor cleaner into the output end of the nozzle,
backflushing it again. Four or five pieces of crud came out, onto the
paper towel, again. Really cleaned the nozzle good, again. Cleaned the
fuel filter and the upper fuel line. Made sure everything evaporated
before I put it back together. Result: works great with the cover on.
Ran the tank of fresh fuel empty. Put the original fuel back in, it
works too.
So, if in the future, I have the problem where it doesn't burn with the
cover on, I'm going to start with the nozzle, upper fuel line and fuel
filter.
Dec 20, 2007 | Reddy R70ET Utility Heater
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Heating & Cooling Logo
265 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
