SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
SOURCE: navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
SOURCE: lorance x25 and x48 configuration, same transducer imput to unit?
The answer is yes. The transducer will fit both units fine without any modification.
See http://primus.lowrance.com/support/resultDisplay.do?docType=1000&contextId=17%3A10.34&clusterName=ClusterPublic&docset=%2FDocuments%2FAccessories&linktosource=1&responseId=135ccbe2cfd4f608%3Adcb03b%3A1218e166f10%3A-5e14&groupId=4&answerGroup=4&score=984&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FAccessories%2FTransducer+Compatibility-Black-192khz.htm&result=5&excerpt=Transducer+Compatibility&resultType=5000#Goto10 for confirmation.
Please rate this solution on FixYa!
SOURCE: installation furuno GP7000F/NT
This unit has built in sonar, so no DFF1 is required. The 1KW transom mount is in stock here, with the proper Furuno 10 pin connector. That is all you need, the display, the power cord, the GPS antenna, the transducer and THE BOOK! We are a Furuno dealer in the Great Lakes
