SOURCE: Refrigerator Freezing
Your refrig has a mechanical damper (the a b or c knob) it may be broken (uncommon ) \ is the freezer fan running even if the cold control is cycled?? Other than that it must be a faulty cold control These are very reliable refrigs and your problem is interesting. Please rate my solution
SOURCE: I have a Frigidaire Side by Side Refrigerator with a defrost problem
You're right! I did change de heater and the fridge is working great now.
thank's
SOURCE: Whirlpool refrigerator gets too cold
This is a
common problem that often doesn't have a clear, permanent solution. The
first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42
degrees. Here are some things to try:
SOURCE: My Frigidaire two door Refrigerator freezes food
door not closing (ajar) or cold control is bad or defrost problem
SOURCE: Magic Chef Refrigerator
I've had a lot of experience with this problem in Magic Chef refrigerators. It was the fan motor in the freezer section not working. It is a fairly easy item to change out and the part runs about $40.
Thanks for your post, friend!
I understand that your ice cream inside of your Frigidaire refrigerator, FFUS2613L. I would turn down your thermostat to see if that would help correct the issue of your ice cream not freezing. I hope this helps. -Matt
