Question about Golf
Why does golf cart yellow light come on 1/2 way thru the round
Posted by Patricia Bourke on
Kyle
    New Friend:
Yes, the solution is to replace the battery, which currently does not meet the requirements. Although the last time I ran into this problem myself, I had to https://golferexpert.com/best-golf-driver-for-seniors/ look for a completely new device. But this is another story and most likely will be decided exactly with the replacement of the battery.
Posted on Jan 22, 2019
Steve Cox
    Master:
  • 674 Answers
Your batteries are not up to par. Replace with new ones.
Posted on Dec 28, 2018
3 Related Answers
Anonymous
  • 24 Answers
SOURCE: I have a yamaha electric golf cart. The lights
I bet that it is an simple as a fuse that blown out. Try replacing the corresponding fuses.
Posted on Nov 07, 2009
fmkaguru0333
  • 4 Answers
SOURCE: step father tring to fix
Give me some more information about this problem. May be i can help.
Posted on Jul 15, 2011
jim nicholas
  • 3 Answers
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Posted on May 15, 2012
MY Yamaha golf cart is fully charged, I play 18 holes and the charger meter drops to about 50% and then the green light turns to yellow, Whats up with that??? Dave
Does the cart move? If you still have good battery power then I would the battery meter. Otherwise you might have a low or bad battery. Need to check each battery under load.
May 22, 2017 | Golf
1986 ez electric 4 seater golf cart serial # 438359
re wire the golf cart. poor ground and possible battery replacement needed
Sep 15, 2016 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Club car golf cart lights
Wiring, fuse and switch. Check for voltage at switch first, if none, check for a fuse in the circuit. I would suspect a fuse or faulty switch first.
Aug 20, 2014 | Golf
We have a 2002 gas club car golf cart and we need a diagram of the key switch starter and can not find a diagram to show the different colored wire connections
black-ground
yellow-white accesory
red-green- 12v constant.
generic application colors.
use a voltmeter and a 12v light to verify all connections.
Nov 03, 2013 | Dual Club Car Lester Power Drive Charger...
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Radio installation in a golf cart
Each battery is 6 volts. You would have to connect to the 1st Battery 12 volts posiltive {+} side and the 3rd battery negative side[-]. Run the positive lead thru an inline 10 amp fuse , then to the radio.
Jul 22, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Golf Logo
376 people viewed this question
Top Golf Experts
ray gallant
Bill Boyd
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
