Question about Speed Washing Machines
We are having an issue with the filter queen am4000 it is on one speed then goes down to lower speed then 5 minutes latter goes back up
Posted by Jennifer Kalogerinis on
4 Related Answers
Anonymous
  • 550 Answers
SOURCE: speed queen gas dryer uses pay cards
overheating and shutting off,
usually is a blockage in the venting
check the exhaust lines to the wall vent/exits, there may be lint build up in those dryers that are shutting off
Posted on Aug 28, 2008
Anonymous
  • 49 Answers
SOURCE: games slow down after 5 minutes and then speed
Try Game Booster software. Its Freeware. You can download it from http://www.iobit.com/gamebooster.html
P.S-Plz don't forget to rate me.
Posted on Oct 17, 2009
BIKER T
Terence Fourie
  • 909 Answers
SOURCE: Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
Posted on May 29, 2010
bunly cheng
SOURCE: Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Posted on Jul 12, 2012
Speed queen electric dryer heats for about 8 minutes then heat goes off and does not come back on
The duct may be clear but the exhaust on the back of the dryer may be blocked. You have to take the back off the dryer and check where the blower is. Good luck.
Mar 25, 2014 | Speed Queen AES28AWF Electric Dryer
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 19, 2010 | Filter Queen Defender Air Purifier
Blinking red light above the lowest setting on filter queen defender air purifier.
Sep 23, 2010 | Filter Queen Defender Air Purifier
Speed Queen CTSAOAWN front loader, makes quite a bit or noise (more than it used to ) when in spin cycle -- rattling, scraping sounds. I'd like to open the front of the unit to see if any suspension...
take front lower panel off.. there will be a white filter housing facing you unscrew abs /plastic clean out usually pennys /dimes quarters put back the same way you took off bingo problem solved<!-- from fixya rte -->
Jul 27, 2010 | Speed Queen CTSA0AWN Front Load Washer
Speed queen electric dryer shorted circuit bracker
Hi
Thanks for using FixYa. From what you have described it seems to be the Thermal fuse that has gone bad. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | Speed Queen AES28AWF Electric Dryer
Need manual for Filter Queen 360 Air Purifier
I'm going to go out on a limb and guess you want the Defender model and not the Majestic model. I believe the latter is a vacuum. Here's a link to the Defender 360 manual. Best of luck.
http://www.filterqueen.com/pdf/defender.pdf
May 27, 2010 | Filter Queen Defender Air Purifier
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Speed queen gas dryer uses pay cards
Aug 28, 2008 | Speed Queen CGS68AWF Gas Dryer
Orange light help
Did you find an answer to your orange light question? I have an AM4000 defender that I bought off Craigslist and thought I got a good deal on it. One minute after turning it on the red light came on. I tried to reset it but  the red light won't flash so you can't reset it. I don't know if it's a filter problem or a circuit board problem and I don't want to spend $100 bucks on filters to find out it's a different problem. If you buy filters on e-bay, they're cheaper but if you spend $100 from a distributor then you reactivate the warranty. I'm sorry I bought it.
Sep 06, 2007 | Filter Queen Defender Air Purifier
Washing Machines Logo
59 people viewed this question
Top Speed Washing Machines Experts
Marvin
Marvin
Vernon Taylor
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
