SOURCE: Executone 64 Administrators manual
if you can get into the programming then first go to the B screen and then press A and set the drop pulse to 10 and then press C for Copy and then Y .
hit ESC and press J
the cursor should be blinking on the first line on top left corner, there hit F for Flash and press ENTER
Hit ESC and press A , put in the EXT you need to program the key for, then press Enter, then K, then K again and pick a key to programm. once you have picked one by pressing ENTER key to move the cursor program a code 815 ENTER, S for Subcode and then 1 Enter
ESC, ESC E for exit.
contact me for more info
SOURCE: Executone 64 System: Only certain extensions ring
http://www.executonesystems.com/documents/IDS_UserGuide.doc
Try going to this user guide and see if this helps.
SOURCE: Executone model 64
In the event you haven't found this information, I got this from www.mainresources.com
To Change The Time
1.
Press the "Menu" key.
2.
Press "Park 3".
3.
Enter the password (default is 456).
4.
Press "#".
5.
Press "1" for System Functions.
6.
Press "4" for System Clock.
7.
Enter the time in 12-hour format.
8.
Press "#".
9.
Press AM or PM by pressing "Park 3" in the LCD screen.
10.
Press "#" to confirm.
11.
Hang up or press "HF".
Top of Page
To Change The Date
1.
2.
Press "Park 3".
3.
4.
Press "#".
5
Press "9819" for the date.
6.
Press the digit for the month (January would be "1").
7.
Press "#".
8.
Press the digit(s) for the day.
9.
Press "#".
10.
Press the digits for the year.
11.
Press "#".
12.
SOURCE: How do I program the Executone model 64 LCD to
I assume you mean change the time and date and that depends on which system model you have....assuming you have an "IDS"...go to the receptionists phone ( the phone you reach by dialing 0 or 3001/ 301 ) and without lifting the handset dial 28 followed by the time in military format...if it worked you'll hear a few quick beeps after inputting the time. You might have an Executone Medley...if so > http://www.mainresource.com/PDFs/TipsMedleySysAdmin.pdf
If you have an older version of IDS you need to program it via a programming terminal or laptop. Leave your email here if you get this and I'll email you - can do it remotely via built in modem.
