Question about Sharp Cell Phones
Sharp 48le653u is stuck on logo loop - Sharp Cell Phones
Posted by Louis mraw on
1 Related Answer
Mark Rego
  • 17 Answers
SOURCE: zte score stuck on muve music screen loop
Hey i've been workin on these ZTE phone and i guess all u need to do is a reset. But the only problem is u will lose all ur data. all u gotta do is First power off the handset, press the Camera key + Power on key +Down volume key together at the same time.
when restart the handset,When display "ZTE", press the Menu key at the bottom of the screen;
Choose "Wipe data/factory reset" through volume key
Press "Camera" key to confirm the above item
Choose "YES...delete all user data"
Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Now once its done ur phone will automatically configure all the factory setup and should work fine,
Posted on Apr 09, 2013
Testimonial: "thank you.....its only been locked up for 8 months......that was too easy....I always over think things.......thanks again "
Bravia 49X8005 continuous boot loop? what do I do?
Corrupted firmware. An update is necessary. Contact the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Oct 08, 2016 | Televison & Video
IPhone 5 went though the wash, so gutted. After a quick google i put it in a sealed bag of rice. Just taken it out n plugged it in and apple logo starts flashing. Does this mean there is hope n it is not...
If the Apple logo keeps flashing and never does anything, it is most likely stuck in a boot loop. You can try reinstalling the OS by connecting it to your computer, but if that doesn't work, the boot loop is most likely caused by a hardware failure.
Aug 06, 2013 | Apple iPhone Smartphone
Boot loop
try pressing the power button and holding it for 10 seconds. Then wait a while. Turn it back on, you may press F12 or other key when the Samsung Logo appears (before Windows Logo) to see the boot options. Choose the one to check for any errors or anything else - Run diagnostics. Then also you may scan your hard drive for any failures.
Jun 04, 2013 | Samsung NF210-A02 Netbook
Sansa Clip Boot Loop
My Sandisk Sansa Clip + is not working, it's stuck on the Sansa logo, the Flower, Refreshing to the Media, Then, it turns back off and starts again, help me Please, Thank you.
Mar 03, 2013 | SanDisk Sansa Clip+
Compaq nc8230 stuck in startup loop after system restore to earlier date
on startup time press F8 for no of times.From option click repair and continue with instruction,When asking for password ,change user name and click enter
Mar 13, 2012 | HP Compaq nc8230 Notebook
Iphone 3g problem with just a apple sign? 100% battery Not charging after going dead!
Are you stuck with just the Apple logo? Did you jailbreak your phone because the apple logo stuck is a symptom of a tethered jailbreak. If yes, you should run Redsnow to get you out of the apple logo loop. If not, try to do a hard reset first by holding the home and sleep buttons for at least 10 seconds until it restarts.
Let me know if you still have problems. :)
Mar 11, 2011 | Cell Phones
Palm 650 stuck in loop
you have to hard reset it. Remove any software that you just install.
May 21, 2008 | Palm Treo 650 Handheld
Cell Phones Logo
61 people viewed this question
Top Sharp Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
