High pressure is usually from heat not being removed from freon in the condensor. Usually it's because the cooling fan is not sucking air through the condensor. Check your cooling fan relays (3) in the battery box in front of the battery. Also, check to see if cooling fan has failed.
Does it work ok when the engine is cold and then quit after engine warm up? That would be a clue. When pressure gets too high, there is a high pressure cut-off switch.
Other posibility is a restrcition in the system. not common though.
go here for more help
http://groups.yahoo.com/group/villagerquest/
SOURCE: a/c in jetta blows hot air, its been charged, compressor comes on.
you need to have it diagnosed by a professional. These are complicated systems even to a trained tech. You may be over or under charged, have a clogged expansion valve, have a leak or many other issues. This model has a rcv refrigerant control valve inside the compressor which regulates the pressure of the compressor. If you notice the compressor never shuts off like conventional auto a/c's do the only time the clutch works is when you turn it on or off. Can be complicated.
SOURCE: 1995 z-28. air conditioner compressor won't kick
Your A/C pressure switch may have gone bad or the wire harness to it may have gone bad. The switch is along the low pressure line or on the A/C Accumulator ( looks like a silver canister) , Unplug the wire and you can jump it there and see if the clutch comes on, if it does try spreading the two tabs apart on the switch and clipping the wire back on. If it does not come back on you need to replace the switch, you can do it with out loosing to much R134A. Just got to be quick when you remove the old one and placing the new one. The low side should have a reading of 30PSI to 50PSI and the high side should have 150PSI to 200PSI. Any other reading will give you poor A/C performance. Good luck and hope this helps.
SOURCE: adding freon to the auto air conditioner, the
On that model,it will cycle on and off while you add freon.If it does not ,then the ac system might have a problem.The low side pressure switch is located on,or near the accumulator .Unplug the switch and take the wire end plug and connect the two plug in`s together(cross it out on the wire).This will make the ac compressor engage and you can charge the system,do not leave the wire connected,plug it back up to switch.If the ac compressor does not come on ,then have the system checked out.
SOURCE: where do you add freon to 1997 mercury gran
You should find a fill stem on the black oblong tank or right next to it. This is the low pressure side. You should get a Vacuum pump which can be loaned from Autozone or Oreillys with a refundable deposit. You need to draw out the moisture in the system and create a Vacuum before you refill it.
You should also use an Oil charge for the compressor. There are Freon cans with the oil charge already in them. However, there are different weights of oil used in the compressor. Let the Auto parts people get you the right type for your car. There are different weights, just like engine oil has different weights.
You will need to jump the connector at the low pressure switch to get the system to take freon. Once you have enough to close the low pressure switch you can remove the jumper wire and fill at will.
