Generally the manufacturer puts the Bluetooth pairing passcode in the user manual. In my experience it’s usually 0000 or something similar. Unfortunately I wasn’t able to find the manual online to get the information for you, but if you still have the manual that came with the device, it should be in there. If you don’t have access to the manual, you could try calling the manufacturer’s support number to request the code—it will be the same for all devices with that model number so it should be pretty easy for them to look up.
SOURCE: pairing my bluetooth to my phone
The Passkey for any bluetooth is 0000 so if you put that in it should work.
SOURCE: passkey of 4 zeroes does not work
I have the exact problem.. but you try to turn off and on your phone once again.. and then do the pairing instruction.... using the passkey 0000.. then... it works for me again...
SOURCE: PASSCODE
hi have motorola h700 bluetooth device but i forget my passcode how do i reset it again i tried many passcode like 0000, 1234, 1111 ,2222, 3333,4444,5555,6666,7777,8888,9999, but its not connecting wat do i do nw.. plz solve my problem.... my email address is [email protected]
SOURCE: bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
