Question about Life Fitness Exercise & Fitness
Where is the fuse located on a life fitness t3 treadmill
Posted by Scott whitaker on
5 Related Answers
vpaaf
Howard
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Posted on May 01, 2009
michaelwitt
  • 74 Answers
SOURCE: I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Posted on Aug 29, 2009
Anonymous
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
Anonymous
  • 83 Answers
SOURCE: FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
Posted on May 07, 2010
Anonymous
  • 83 Answers
SOURCE: Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
Which treadmill should I get?
Dear Sir, all depend how much do you want to spend
Guide from some friend, relative or some nutrional instructor.
God bless you
Oct 18, 2012 | Life Fitness T3 Treadmill with Advanced...
Where can I find service manual for Life Fitness T3 Treadmill
service manual can NOt be provided to some customer. Otherwise you must contact to the factory, and explain.
However you can reach by buying online from www.fitnessrepairparts.com
God bless you
Aug 27, 2012 | Life Fitness T3 Basic Treadmill
My treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
May 04, 2012 | Life Fitness T3 Treadmill with Advanced...
T3 - It slows down then speeds up, has mind of its own.
It sound like the Motor Control Board is failing call Life Fitness @ 1-800-351-3737 they will give you additional information and locate a servicer in your area
Jun 12, 2010 | Life Fitness T3 Treadmill with Advanced...
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
FET Error
Nov 08, 2009 | Life Fitness T3 Treadmill with Advanced...
Aug 29, 2009 | Life Fitness T3 Treadmill with Advanced...
Exercise & Fitness Logo
66 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
