Question about Sanyo Video Cameras
I try to operate my Sanyo VM-EX30P camcorder, but despite connecting it by battery or by mains lead it will not work. any suggestions?
Looking down the eyepiece, when I slide the power switch to player, it doesn't light up and I can't eject the cassette tape in the camcorder.
Posted by Robin Bagnall on
Tony Parsons
  • Sanyo Master
  • 6,301 Answers
Battery probably needs replacing.
Posted on Dec 26, 2018
5 Related Answers
Marty marty
  • 883 Answers
SOURCE: removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Posted on Jun 06, 2007
Anonymous
SOURCE: Canon zr300 ejects tapes
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Posted on Mar 24, 2008
ilragatzzo78
francisco navarro
  • 241 Answers
SOURCE: cassette player
the tape is very tight
get a pen and try to loosen up the tape
100 % is the tape not the radio
Posted on May 16, 2008
Anonymous
SOURCE: Cannon MD101 Wont eject Tape /No Power
same problem :(
Posted on Oct 05, 2008
INTERLOGIC
SABARI ANAND
  • 326 Answers
SOURCE: i have a tape stuck in my sony tc we645s cassette deck
try factory restore settings
Posted on Apr 14, 2009
Sanyo vm d6p video 8 camcorder will not record. Any suggestions?
The organic electrolytic capacitors leak and cause issues
Apr 02, 2017 | Sanyo Video Cameras
Where do i get battery for sanyo ps120p
NP55 or 65 battery pack which is just aa batteries. Build your own pack with aa batteries and solder them in series and insulate.
Feb 25, 2011 | Sanyo VM-PS12 8mm Analog Camcorder
I have old tapes from an old camcorder Sanyo VM-D66P that I want to capture to my pc, how do I do this?
There are several ways of converting your tapes to a digital format.
1. By routing it through a DV camcorder with AV-input (these are increasingly rare though. (using firewire).
2. By using a device like this, which converts to DV. (also connects via firewire). http://www.dv247.com/invt/23453
3. By using a device which captures to MPEG2.
The cheapest way is option 3, but it requires a working camcorder. You should purchase a device similar to this: http://www.avforums.com/forums/attachments/camcorders-video-editing/85846d1216145397-camcorder-computer-easycap.jpg
If you don't have your camcorder anymore, or it isn't functioning, you should try to get a second-hand 8mm camcorder with firewire. This way you are able to directly convert your tapes to your pc.
If you can't find a firewire camcorder you could just settle with a good functioning 8mm camcorder but you will have to buy a capture device as mentioned above.
Jun 06, 2010 | Sanyo Video Cameras
C31.23 error
This means: A mulfunction occured that you can not service.
SOLUTION:
You may try these:
1. Eject the casette and insert it again, then operate your camcorder.
2. Disconnect the mains the lead of AC Adaptor or remove the battery pack. After reconnecting the power source, operate your camcorder.
Mar 26, 2010 | Sony Handycam DCR-TRV250E Digital...
MY SANYO CAMERA MODEL 8MM VM-d66P SHOWS A WHITE
IF YOU CANT GET THIS FIXED CAN I BUY IT FROM YOU AS I NEED A 8MM CAMERA TO CONVERT MY TAPES TO DVD AS MY OLD 8MM CAMCORDER WONT PLAY.OR DOES ANYONE HAVE ONE I COULD BUY CHEAP OR BORROW...IN MELBOURNE AUSTRALIA...CHEERS JB
Jan 09, 2010 | Sanyo VM-D6 Camcorder
Tape wont eject
The deck may have went. Try bringing it to a local camera shop to get it out for you.
Dec 31, 2008 | Sanyo VM-PS12 8mm Analog Camcorder
DEW indicator / battery
In your owners manual on page 52 you will find a list of authorized service centers. Give the one in your area a call. Give them the brand name and model number of the camcorder. Tell them you are having a problem with the dew warning coming on while using the camera with the battery. They should be able to help find a answer to this problem.You can also call the panasonic customer support telephone number at 1-800-211-7262 between the hours of 9am-7pm EST. Give them the brand name and model number of the camcorder and ask them for help with the problem of dew indicator coming on while in use with the battery. I hope this information helps you with your camcorder problem.
Nov 20, 2007 | Quasar VM-L450 Camcorder
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Video Cameras Logo
259 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Nicola Conroy
abdul rauf
abdul rauf
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
