Question about Measuring Tools & Sensors
Turn off alarm in XC-0366 - Measuring Tools & Sensors
Posted by Graeme Hayhow on
James M Knox
    New Friend:
  • 31 Answers
According to the manual, it's all about the "DOWN" button.
Activating and deactivating the alarm:
To activate or deactivate the alarms, press the 'DOWN' button:
- Press once: Alarm 1 activates
- Press twice: Alarm 2 activates
- Press three times: Both alarms are activated
- Press four times: Both alarms are deactivated
That should do it...
Posted on Mar 05, 2019
2012 KTM XC 300 W need to change the long outside power valve spring
Hi, Russell, the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Rocky Mountain Dirt Riders
2013 KTM 300xc power valve spring adjustments
2012 KTM 250 300 EXC XC Service Repair Manual pdf
https://www.partsfish.com/page/oem-parts-for-ktm
125 300 exc xc xcw sixdays 2012 ownersmanual pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 16, 2018 | 2012 KTM XC 300 W
Acer aspire xc-603 wont start up
can be a dead CMOS battery or some Power supply issue.
the best thing is to contact the official Acer support service.
Jun 01, 2016 | Acer Aspire Xc-603 Compact Desktop/...
How do I change the temperature display on a Digitech XC-0366 weather station from Degrees F to Degrees C?
Pressing the - (minus) button on the back toggles temperature units. Pressing + (plus) toggles barometric pressure units.
Feb 26, 2015 | Measuring Tools & Sensors
Alternative number for 0844 387 6630
0366 783 4480 / 783 0366 4480 / 03664484783
Feb 21, 2015 | Televison & Video
Holden Barina XC 2001 heater not working
check that when you turn on the heater control that it is actually turning on the hot water tap. They are mostly vacuum operated and the little hoses break or rot or become pinched.
Jun 11, 2013 | Cars & Trucks
HP photosmart C6180 tout-en-un message d'erreur Err Oxc18a0106 BESOIN URGENT D'AIDE EN FRANCAIS .MERCI
Retirer les cartouches du produit.
afficher sur le panneau de contr?le. " xc="1.Wait for the 'Insert Cartridges ' message to display on the control panel." closure_uid_u4snr0="101">1.Wait pour le message "Ins?rer les cartouches" pour afficher sur le panneau de contr?le.
produit. " Xc="1.Disconnect the power cord from the back of the product." closure_uid_u4snr0="102">2.D?connectez le cordon d'alimentation de l'arri?re du produit.
secondes. " Xc="1.Wait 60 seconds." closure_uid_u4snr0="103">3.Attendre 60 secondes.
4.Rebranchez le cordon d'alimentation. produit n'est pas automatiquement en marche, appuyez sur le bouton Power (). " Xc="If the product does not automatically turn on, press the Power button ( )." closure_uid_u4snr0="105">Si le produit n'est pas automatiquement en marche, appuyez sur le bouton Power ().
cartouches, puis fermez toutes les portes ouvertes sur le produit. " Xc="1.Reinsert the cartridges, and then close any open doors on the product." closure_uid_u4snr0="106">5.R?ins?rer les cartouches, puis fermez toutes les portes ouvertes sur le produit.
vous recevez une invite pour imprimer une page d'?talonnage, le faire. " Xc="1.If you receive a prompt to print a calibration page, do so." closure_uid_u4snr0="107">6.Si vous recevez une invite pour imprimer une page d'?talonnage, le faire.
USB ? l'arri?re du produit, puis relancez l'impression." Xc="1.Reconnect the USB cable to the rear of the product, and then try printing again." closure_uid_u4snr0="108" >7.Rebranchezt le c?ble USB ? l'arri?re du produit, puis relancez l'impression. si>vous avez suivi toutes les ?tapes ?num?r?es ci-dessus et connaissent encore un probl?me, le service du produit
Dec 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Rear tine will not turn mod 21b-403-13144-0366-6 huskee
Could be the belt if it has one. If not then your problem could be as simple as a pin broken in the tine shaft. There is also a pin in a gear in the gear box also, This will require shop work.
good luck.
Oct 03, 2009 | Garden
Measuring Tools & Sensors Logo
172 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
