SOURCE: no sound from right speaker when mp3 connected through aux
Hi bustero78
What happens when you rotate the plug or wriggle it about. If it cuts in and out, then you may have a faulty interconnect lead, or a dodgy socket/plug connection to the player. If it works with headphones, I would suggest replacing the lead.
I am more than happy to answer
any other questions you may have about it, just give me a hoy :) If you
are still unsure, or have problems, then before you give a rating for this advice, please
get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you
as sound, a FixYa rating is a great reward for my efforts to help
you. Cheers.
regards
robotek
SOURCE: OVER HEAT
To reset the the T743 hold down the video 6 and the source up buttons for 3 seconds. then power up from the back button
SOURCE: NAD 7140
The clicking is the sound of a bad relay. A relay is an electrical switch that opens and closes under the control of another electrical circuit. There is no user solution for this. You'll have to take it to an electronics repair shop (~$150) or dump the whole unit.
SOURCE: no sound output from coaxial port on philips dvdr 3475
try setting your av signal selector to auto. if that daes not work go to your av set click on digital input setuo an make sure you have got one of your coaxial slots asigned to dvr1. you will get better sound by using a coaxial or optical hookup compared to hdmi. i've tryed both. hope this helps you , if it don't email me back at [email protected]. i also has a ppioneer av reciever, so i've been through the same trile and errors
SOURCE: NAD T743: The digital channels stop working after a short time.
I had the same problem just once, about a week and a half ago. Don't tell me that this problem is going to get worse.
Register and download the manual for free at retrevo.com
