An "F11" typically stands for a shorted keypad. You can reset your appliance by unplugging it or disconnecting power for ten minutes. If you perform this step and continue to receive an "F11" it could be an issue within your EOC (Electronic Oven Control) and I would recommend having a professional come out to properly diagnose your range
SOURCE: Whirlpool Duet Error Code F11
its your ccu board under top in back easy to change about 300.00 that is f 11 code "plz"
SOURCE: F11 code on my kenmore range. The repair says the
No. Other than order the part from Sears.com and install it yourself.
SOURCE: Hi,Im tech and I have a problem with range
The F10 F11 F12 F13 F14 Error Codes indicate that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&^%TG
SOURCE: How fix blown element on Electrolux induction range?
If it's a year old and under a 5 year warranty then it will be covered under the warranty and shouldn't cost you a dime. If it happens again then speak to someone about getting a different range since you may have received a lemon.
Thank you for your inquiry, Katherine!
Based off the information you have provided your Frigidaire range is displaying an error code of "F11". An "F11" error code stands for a shorted keypad I would recommend performing a reset on your range. You can do that by flipping off the household circuit breaker for at least ten minutes. If that does not correct your issue it could be a possible problem with your EOC (Electronic Oven Control) or wiring harness. Hopefully this information is helpful for you. -Matt
Thank you for your inquiry, Warren!
From my understanding you are receiving an error code of "F11" on your Frigidaire range. Typically an "F11" code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by disconnecting power from your range for roughly ten minutes. If that does not help correct your issue you may need to replace the EOC (Electronic Oven Control). This is not a simple DIY job and I would recommend having a professional technician out to assist you with replacing the electronic component. Hopefully this is helpful. -Matt
Thank you for your inquiry, Phillip!
From what you have described your Electrolux range is displaying an error code of "co55". I was unable to locate that specific error code. It might be a display error with your range and I would suggest performing a reset. You can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help correct your issue could you please provide me with your model number? With that information I would be able to assist you further. -Matt
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
Hello friend, thank you for your post!
I understand that you need troubleshooting steps for an "F11" error code. "F11" stands for a shorted keypad and one step for troubleshooting is to reset your range. You can reset your range by flipping the household circuit breaker off for ten minutes. If that does not help correct the "F11" code I would recommend you reach out to a professional for proper diagnosis because it could an issue with your EOC (Electronic Oven Control) or wiring harness. I hope this is helpful. -Matt
Hey friend, thanks for your post!
An "F11" typically stands for a shorted keypad. You can reset your appliance by unplugging it or disconnecting power for ten minutes. If you perform this step and continue to receive an "F11" it could be an issue within your EOC (Electronic Oven Control) and I would recommend having a professional come out to properly diagnose your range. -Matt
Hello Nancy Keller - Typically, error code F11 indicates a shorted keypad. Try resetting the wall oven by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
