SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
SOURCE: changing spark plug on a Stihl 410 cut off saw,
right by the decompression valve is the spark plug. if you remove the one screw for the valve you will see that to get access to the plug is very easy,
Posted on Mar 04, 2010
SOURCE: no spark in stihl 025 chainsaw. I replaced the
Where did you get the coil? How did you gap the coil? Reply below please.
This tests the entire system:
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 16, 2010
SOURCE: stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Posted on Apr 20, 2010
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
Jul 30, 2016 | Stihl Garden
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Feb 08, 2016 | Stihl TS420
Dec 12, 2012 | Stihl Ts 410 420 Cut Off Saw...
Sep 26, 2012 | Stihl Garden
Aug 15, 2012 | Stihl Ts 410 420 Cut Off Saw...
Jun 22, 2012 | Saws
Dec 27, 2010 | Stihl Ts 410 420 Cut Off Saw...
Nov 07, 2010 | Stihl Ts 410 420 Cut Off Saw...
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
May 08, 2018 | Stihl Saws
127 people viewed this question
