SOURCE: 42" Sharp Aquous audio; Mono vs. Stereo
no. that is not true. the person you spoke to obviously didn't know what they were talking about. you mean to tell me that everyone that has a cable or satellite box with a stereo or hd tv is not going to receive stereo sound? really,think about it. you only need a cable box( for now ) if you have premium channels (hbo,showtime etc). you can connect the cable line right into the tv if you only have basic cable. look at the back of your cable box. if you have a red, white, & yellow audio/video output, then the box is stereo.connect these outputs to your tv. this connection however is not hd.you will need a hd box with a hdmi cable for hd .To put the tv on stereo mode, there should be a way via the menu and/or the audio button on the remote to get it off mono and put it on stereo. your manual should at least show you around the settings of your tv.
wg
SOURCE: I have a Aiwa Stereo Receiver Av-D58. The sound
If I remember this model correctly, there is only 1 direct input. The remainder of the inputs are bufferred through a switching IC. It is likely that this IC is defective. Are there any other symptoms at all?
Thanks,
Dan
SOURCE: 5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
SOURCE: hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Testimonial: "worked like a champ!"
