Question about Razor Cycling
How to repair a razor electrical bicycle controller
Posted by Michael Smith on
2 Related Answers
Anonymous
SOURCE: repairing electric razor
Questions,
What can be done to eliminate self-starting; slide switches which have become exremely sensitive to the touch and often times turn on when set down after use.
Slide switch covers no longer return to full "off" position. Ive had to use scotch tape to prevent them powering on when placed in suitcase, for example. Is this problem characteristic of Braun razors?
Can a nonprofessional open up casing to administer a very thorough cleaning? And where would one get an instructional schematic? Can one be obtained from Braun?
Thx!! Vince
Posted on May 25, 2008
Michial Gueffroy
  • 1140 Answers
SOURCE: where do I find a manual on electric bicycle
I'd try www.parktool.com/ Also try www.sheldonbrown.com
Posted on Jun 23, 2009
What is wrong when full power on throttle but only clicks
Check the battery voltage right after the charger shuts off. Should be around 13 volts on each one. Short the power switch contacts and if that helps replace it. Check that the motor and wheel turn freely and dont make noise. Check all the contoller connectors. Sometimes they melt and the connection isnt good. You can always connect the batteries directly to the motor and if it goes full speed then you need what razor calls an electrical kit which has a throttle and controller.
Jul 23, 2014 | Razor MX500 Dirt Rocket
Can you increase the speed on the new 350 razor dirt rocket
MX350 is a 24V bike.
You could change the gearing by replacing the sprockets, or you could replace the electric controller and upgrade to 36V, but you probably would be better off getting a bigger model, like the MX500, as this uses 36V already and the higher voltage allows for higher motor rpm.
Dec 26, 2012 | Razor MX350 DIRT ROCKET - BLUE
Wont charge tryed a new charger think its the battery can i replace the battery ?
Razor E100 batteries are easily replaced & there are guides on how to this on razor.com, genuine Razor batteries are available at most good Razor product stockists.
Dec 30, 2010 | Razor E100 Electric Scooters Red
How to fix flat tire.
Hi:
I have a rascal 3 wheel chair and the tire is flat on back, how do they come apart for repair, thanks.
Leroy
Mar 28, 2010 | Razor E100 Electric Scooters Red
How do you get the tire of the rear rim of the razor mx500 electric dirt bike???
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
Jun 09, 2009 | Razor MX500 Dirt Rocket
Resistor r4 cracked on controlmodule for e100
if you remove the resistor and take it to an electronics shop they can tell the rating from the colored bands that are around it.
Mar 15, 2009 | Razor E100 Electric Scooters Red
Cycling Logo
200 people viewed this question
Top Razor Cycling Experts
Andrew Taylor
Andrew Taylor
ray gallant
steve
Are you a Razor Cycling Expert? Answer questions, earn points and help others
