Question about Igloo Cooler Igloo Portable Countertop Ice Maker
Igloo portable ice maker fan is making grinding noise. How to clean it?
Posted by Monica Reed on
5 Related Answers
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: portable ice maker not working as good as it did
Hi
Kindly refer to the Haier service manual which will help you for sure.
Thanks
Rylee
Posted on Jan 30, 2009
reyjoshua07
Reynaldo Labaguis Jr.
  • 1157 Answers
SOURCE: the ice maker won't stop
Hi slh3095,
The easiest way to stop the ice maker in making ice is by raising the shut off arm.
Please check if the shut off arm can move freely.
Here are additional steps that you can apply to stop the ice production:
1. Raise the ice maker's shutoff arm until you hear a click and the arm stays in the up position. The ice maker will remain off until the shutoff arm is pushed down.
2. The shutoff arm is designed to automatically stop ice production when the ice bin is full. Using an ice bin other than the one designed for use with the refrigerator may not allow the shutoff arm to stop ice production.
3. Ensure that food packages, ice packs, etc. are not obstructing the wire shut off arm so it can move freely.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 01, 2011
i_rodrigu37275
i.rodriguez
  • 11 Answers
SOURCE: My Igloo ice 102C is making a loud noise when it pumps in water to make Ice. How do I fix this
It shouldn't make any loud noises at all. Most likely it's a water pump related problem. Most pumps make loud noises when they are lose from their base due to a broken clip or untighten screw. It could also be caused by a faulty pump. Either way, if you just bought it and have the receipt, return it and have them give you another one.
Posted on Dec 02, 2014
joeaxe
Joseph Coppeto
  • 360 Answers
SOURCE: Hello, I have a portable ice maker model 102C igloo . the machine turns on but will not continue the cycle and the ice full red light comes on. Any answers to this problem are welcome.
The tray full may be triggered or stuck or another problem may exist. Look for what senses the ice being full and also check with Curtis support:
(another person was tld to do this and it workd:
1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hours.
I included some links for your convenience. Good Luck
1 How to fix portable ice machine part 1 of 3
Troubleshooting Portable Ice Makers
Igloo ICE102 WHITE User Manual Troubleshooting Guide
Posted on Apr 29, 2016
iam6fan
Chris Huff
  • 6289 Answers
SOURCE: igloo ice maker won't make ice. what's wrong?
Water valve possibly defective
Posted on Oct 09, 2018
Igloo countertop ice machine says tray is full when empty and will not make ice
Hi I had the exact same issue after about a year of running my igloo ice maker non stop. To fix it I held in the on/off button and select button at the same time for about 30 sec and TADA!! Back to making ice.
If that doesn't work I've also read to leave machine unplugged for 6 hrs and then hold in on/off button for 10 seconds. Good Luck!!!!
Sep 13, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Why is my igloo portable ice maker hot?
The heat that is being removed from within the unit has to be extracted towards the outside. A lot of times the condenser coils are on the surface just underneath the exterior panels.
Mar 19, 2015 | Igloo Cooler Igloo Portable Countertop Ice...
My 26lb silver portable ice maker wont make ice?? Any suggestions???
does it run? does the compressor run, does the fan run, is the air flowing across the outside radiator, is the air comiing out warm? is there a waterpump and does it run? Does anything get cold and does anything get hot?, it should be. These are my suggestions to look for in your unit
Dec 31, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Dec 02, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
How to clean igloo portable ice maker
Maybe scaling has occured, get descaling chemical to clean it. Also remember to remove the dust accumulate at the condenser..
Oct 11, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Ice full when no ice portable ice maker
There is some sort of arm that fits into the ice tray; when the ice fills up the tray the arm is pushed up and a switch connected to it will open the circuit and prevent any future ice maker operation(s). That switch has to be closed for unit to work!
Nov 12, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
My portable igloo icemaker is not making ice
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Mar 05, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Igloo Cooler Igloo Portable Countertop Ice Maker Logo
530 people viewed this question
Top Igloo Cooler Freezers Experts
Bill Boyd
Renee Knafel-Bullock
J Rosado
Are you an Igloo Cooler Freezer Expert? Answer questions, earn points and help others
