Indesit integrated dishwasher Model DIE2B19UK when I try to start a new cycle, press play, close the door it beeps and when I open the door all lights are flashing
When you attempt to start a new cycle on your Indesit integrated dishwasher (model DIE2B19UK), the dishwasher beeps, and the lights begin to flash.
Various factors could be to blame for this problem.
A few troubleshooting tips are provided below:
Examine the door:
The dishwasher door should be securely closed and latched.
The dishwasher will only start if the door is properly shut.
Verify the water inlet:
Verify that the water inlet is turned on and that the inlet hose is free of glaring obstructions or kinks.
Check the filters: Check the filters in the dishwasher for any blockages or debris. Clean or replace the filters as necessary.
Check the pressure switch: The pressure switch is responsible for sensing the water level in the dishwasher. It could be malfunctioning, which is causing the dishwasher not to start.
Check the control board: The control board controls the dishwasher's functions. It could malfunction, causing the dishwasher not to start or displaying the error code.
Contact the manufacturer: If none of the above solutions work, it may be necessary to contact the manufacturer for further assistance. They can provide more detailed troubleshooting steps or recommend a service professional to diagnose the problem.
