Amit sharma Posted on Dec 24, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have panasonic pt-ex500 projector When i press power botton green light will glow after that with in a quarter minute all light are blinking What cause is this please help
Lampdeng.com
Level 2:
Renaissance:
An user who is expert in 3 categories / brands.
  • Expert 789 Answers
  • Posted on May 31, 2019
Lampdeng.com
Expert
Level 2:
Renaissance:
Answers
789
Questions
0
Helped
197519
Points
977
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
I am an expert of repairing projectors for 19 years.
It is my pleasure to receive the message form you,
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
5 Related Answers
A
Anonymous
  • Posted on Mar 27, 2008
SOURCE: No Picture on my nec VT676 model
Thanks. NEC did not have a solution for us, but the solution for us was to replace the bulb. You'd think they would make that a bit more obvious!
Thanks.
Anonymous
  • Posted on Dec 17, 2008
SOURCE: TV WONT TURN ON
I found the problem with my set! I pulled out the lamp to inspect and low and behold the filiment was burned out. Just ordered a new lamp to replace it. That should fix it.Very easy to pull the lamp .
Anonymous
  • Posted on Jan 22, 2009
SOURCE: Panasonic PT-56LCZ70 no picture or sound
My name is Jonathan and I am an employee at the Panasonic Customer Call Center. Based on the symptoms you've described, I'd recommend contacting the Panasonic Customer Call Center at 1-800-211-7262 for assistance. We are here to help customers that have purchased (or are considering purchasing) our products and would like to assist you with resolving the symptoms described here. Our hours of operation are:
Mon - Fri, 9 AM - 9 PM EST
Sat - Sun, 10 AM - 7 PM EST
Anonymous
  • Posted on Apr 08, 2009
SOURCE: Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Anonymous
  • Posted on May 13, 2010
SOURCE: the projector lamp does not turn on
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
1helpful
How to reset lamp hour of panasonic pt lam1 lamp
hi,
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • 1helpful
    What is wrong with my Panasonic PT-L711XU projector?
    try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
    jahting
    Panasonic PT L501u Replacement Lamp
    panasonic projectors , even if the lamp has reached end of life gives u 10 minutes to reset the lamp counter
    so when u replace a new lamp, go to options, lamp counter, reset & press stanby button for confirmation!
    thats all the unit powers off & when u check the lamp counter , its shows 0
    u r done!!!!!!
    Panasonic pt ae900 wont fire up
    First , start over and unplug it. Wait a few minutes. Turn on AV system that is connected to it but not video or dvd player. With remote, point at is corectly and push power 1 sec or as soon as you see green light come on. Be quick.
    If this fails you can wait 4 hours and repeat. OR try only projector with out any feed.
    Let me know if this worked.
    4helpful
    2answers
    PT-LC50E LCD Projector
    With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
    I wish they could have stuck this in the operators manual.
    Top Panasonic Office Equipment & Supplies Experts
    Norman Weimar
    Norman Weimar
    ZJ Limited
    ZJ Limited
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
