i´m working on mac with a 600gb lacie disk the disk image appears on screen but i cannot see the data, I have tried with tech tools and with disk warrior software but the same message appears : the disk cannot be un mountedi´m working on mac with a 600gb lacie disk the disk image appears on screen but i cannot see the data, I have tried with tech tools and with disk warrior software but the same message appears : the disk cannot be un mounted
You can't post conmments that contain an email address.
your drive can be used with any D2 or Big Disk power supply as well as some LaCie Porsche power supplies (you need to make sure the connector is the same).
Searching for LaCie Power supply on eBay will give you a few hits that match your needs.
Regards,
If the power supply doesn't delivers the correct current the hard disks can't spin fast enough and this is detected as a failure by the pc, which cuts the connection. Hopefully by replacing the source all will go back to normal. Otherwise you will have to crack open the cases, remove the disks and install them directly in a desktop to try to access the data on them.
Just cocnect it on a computer and boot from a live cd, somethig like linux or erd commander, and copy your files to a nother drive than u can format your disc and reset the protection...
from the description either th drive or the 1394 logic board has failed. Try having the technicians at you local PC shop swap the actual hard drive from the Lacie enclosure into a new enclosure and test it. If it works, buy the enclosure and you're back in business, if it oesn't and you need the data on the drive comment back with your Country, State & City and I'll refer you to a good Data recovery specialist in your region.
It's all about the interfaces.
The Quadra has four interfaces:
• eSATA
• FW 400
• FW 800
• USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
