Question about Bernina Sewing Machines
The feed dogs on my Bernina 1130 is not working. How do I correct the problem?
Posted by Sue Hakes on
Shirley Neibarger
    Novelist:
    Scholar:
  • Bernina Expert
  • 90 Answers
On the right side of your machine, below the hand wheel, there is a small knob. When you are free hand quilting, darning, etc. you can turn that knob to the right until the dot on the knob is pointing to a small picture that looks like a crazy railroad track :)
After you want to sew again, you must turn that knob back until the indicator is pointing to a small picture that looks like 3 tiny mountains above a dotted line. Once you turn it back and start to sew, the feed dogs should pop back up.
If you have your knee lift in and tend to lean your leg against it, sometimes it slightly lifts the foot as you are sewing and with the Bernina, it drops the feed dog when that happens.
Good Luck
Posted on Dec 26, 2018
5 Related Answers
RickE1
Rick
  • 202 Answers
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Posted on Feb 07, 2009
ken dourof
  • 980 Answers
SOURCE: My old Bernina 1130 has never given me trouble,
If you have a drop feed mechanism make sure you have not dropped the teeth down by mistake, make sure you have enough pressure on the foot, remember you should not be able to pull the fabric through by hand if the teeth are up
Posted on Nov 01, 2009
SOURCE: Bernina 1130 zigzag stitch for applique stops moving
have you tried changing the needle
Posted on Apr 25, 2012
Testimonial: "Will try that, thanks."
Miriam S
SOURCE: bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Posted on Aug 11, 2012
99rannellis
R.A. Ellis
  • 12731 Answers
SOURCE: The feed dog on my bernina 1130 is not working. IT will not pull the fabric.
Even if you select a longer stitch? Have the feed dogs been dropped for darning? Otherwise, your mechanical machine may be seizing due to old oil that has solidified.
Wheel on right side that controls the needle up and down is very tight...
Posted on Sep 08, 2017
Bernina Nova 900. Feed Dog Adjustment and Troubleshoot (Any manual}
1: remove the open arm cover by pressing the lever just under the needle plate to the upper left of the bobbin case door.
Clean out the lint between the feed dogs.
Replace open arm cover and the feed dogs at the highest rotation should be the height of a dime above the needle plate.
If this is correct then done. If the feed dogs are still to low
remove the needle plate again and in the right hand side of the open arm area, there are two small screws on right feed dog bar. Loosen them move feed dogs up and down to required height(above) retighten screw very tight. Done
Sep 30, 2018 | Bernina Sewing Machines
Sep 08, 2017 | Bernina Sewing Machines
I have a bernina 1130 the feed dogs have dropped and will not feed fabric. I have make sure on the right knobs that it isn't on with dogs down mode. Please advise as to problems to look for.
If it were mechanical, my suggestion would be to oil, but this is a computerized machine. The manual instructs to only oil the hook/shuttle area.
There are some excellent Bernina groups on Yahoo Groups. One is "BerninaThirtySomethings" that has quite a few very knowledgeable Bernina users and some techs who may be able to provide some suggestions. You will need a Yahoo email account, search for the Bernina groups, and then request to be added. Once added, you can post your questions.
Jan 07, 2017 | Bernina Sewing Machines
The presser foot doesn't sit all the way down in order to sew correctly. Can I adjust it myself? How?
Has that particular presser foot worked in the past? Do the other presser feet work?
If it hasn't been used before, check that it is the correct foot for the machine. Is it perhaps a darning foot or free motion foot? If so, those particular feet are made to Not rest on the feed dogs so that the fabric can be manually moved without the use of the feed dogs.
If none of the presser feet work with the machine, then the needlebar has probably shifted. It may be best to take it for service as it may require specific tools and gauges to adjust it properly.
Presser feet for every purpose
Manual:
https://www.bernina.com/en-US/Support-US/Machines/BERNINA-artista/BERNINA-artista-180
Jun 05, 2016 | Bernina Artista 180
Bernina 1130 feed dog does not move fabric, the dog just moves up and down
This problem maybe cause by the stepping motor being sealed or the main board problem. Please go to your local sewing machine mechanic.
Dec 24, 2013 | Janome Memory Craft 4800QC
My old Bernina 1130 has never given me trouble, but today, it seems like the control for the stitch length stopped working. The feed dogs are moving, but the stitch is very, very tiny. Will this be an...
Nov 01, 2009 | Bernina Sewing Machines
Bernina 1130 feed dogs won't feed fabric
Apr 10, 2009 | Bernina 1008
Sewing Machines Logo
771 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Wayne Buss
Douglas Plant
Douglas Plant
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
