Ovens Logo
Question about Ovens Ovens
I have double Gooldseries ovens. We had extended power failure and when power was restored I attempted to preheat top and hen bottom ovens and get “feature not available”
Posted by Sandy Jones on
LarryT
    Dedicated:
    Visited the website for 20 consecutive days.
    Passionate:
    Visited the website for 10 consecutive days.
  • 15 Answers
Try a power reset:
Reset power to the product:
Power unit down by turning off the circuit breaker(s) or fuse(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s) or fuse(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Is there an error code?
Posted on Dec 24, 2018
4 Related Answers
Anonymous
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Dacor Electric Double Oven - bottom oven won't heat
If ti has a timer that is flashing auto, reset it to manual , as it will not work in auto mode.
Hope this helps.
Plz rate soltuioun.Thanks
Posted on Dec 27, 2008
SOURCE: Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Posted on Apr 05, 2014
rldev
Bob Bond
  • 219 Answers
SOURCE: Have baumatic double oven after power failure to house reset consumer unit top oven works but main bottom oven doesn't, no lights or anything. Anybody have a idea?
try resetting the clock, it may have gone into auto timer mode.
Posted on Jul 02, 2015
2answers
Why does the top oven not heat up, and bottom oven works fine
Good Morning Friend,
I understand that the top oven does not heat up in your Frigidaire oven, but the bottom oven works fine. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and set the clock. Try preheating the top oven. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please provide me with the model number of your air conditioner. Hope this is helpful.
-Best Regards-
WP
Main oven causes trip switch to trip out when `I turn the dial to switch on. Top oven is fine.
Likely the element is shorted in the main oven. The Calrod elements short usually at the bends and if the breaker doesn't trip they burn a hole in them and arc. You can USUALLY see a different discoloration at teh failure point. Check both upper and lower elements as preheat probably uses both. Use a dental mirror if necessary to see under and over. Use bright light.
1helpful
I have a KitchenAid double oven with convection on the top and conventional on the bottom (model #KEBC207KBL0). When I set the temperature and preheat the top oven, the display shows the temperature rising...
it will either be the sensor or the board,hopefully it's not the board,the part number for the sensor is 4455636 and subs to w10131825,the sensor is around 100 bucks,there should be a tech sheet on the machine most likely behind the touch pad on the top,it will tell you how to check the sensor with a meter,just unplug the sensor and read it out i think it's around 1100 ohms but check that on the tech sheet,if it's not the sensor most likely it will be the board part number 4453661 and that's around 300 buckseverything runs through this computer board but the sensor tells it how hot it is in the oven hopefully you have a bad sensor.let me know what you find,you'll most likely have to pull the oven to repair it but maybe just enough to get the top open,good luck
2helpful
Frigidaire FES367ASE Slide in range
Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
1helpful
Hope this helps.
Dec 26, 2008 • Ovens
1helpful
Stoves 720ef electric double oven not working
According to the circuit diagram on page 31 of the handbook, power for the ovens passes through the clock. The power feed is direct for the actual clock but via a seperate Thermal Cutout for both the top and bottom ovens. I think it is highly unlikely that both Thermal Cutouts have failed at the same time. I would try turning the power off totally to the oven for a while and then turning it back on, set the time and ensure the oven is in manual mode. As the top and bottom ovens have seperate controls after the Programmer and both are not working, it has to be the programmer that is not extending the power through to the rest of the oven.
Bottom oven of dacor double oven
Open Questions:
Top Ovens Experts
ADMIN Andrew
ADMIN Andrew
Tom Chichester
David Spradling
David Spradling
Are you an Oven Expert? Answer questions, earn points and help others
