Cameras Logo
Question about Nikon Cameras
How to open battery door
Nikon coolpix
Posted by Jennifer Walter on
5 Related Answers
Anonymous
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Posted on Mar 26, 2008
Anonymous
  • 6 Answers
SOURCE: Replacing the battery door on a Nikon CoolPix 4600
Call 3104148107 This is the Nikon Parts line, be warned it will probably take as long as 30-45 minutes of old time to get to a person.
Once you can get to a person, give them the camera model and describe the problem. They just sold me a replacement battery door for $9.95 + $6 dollars shipping and handling.
The rep was so nice he even printed out the device design blow up, and the relevant section of the manual, so I could see the step by step with out having to purchase the full blown repair manual, which runs $83.
Posted on Sep 02, 2009
leethedeuce
Lee A.
  • 4472 Answers
SOURCE: "Lens Error" message in Nikon Coolpix L5
There are a few different things it could be though most likely the lens itself is out of alignment. There are methods you can try to "click" it back into place. First off how long have you owned the camera?
Thanks,
Lee
Posted on Sep 14, 2009
Anonymous
SOURCE: The latch on the battery door of my Nikon Coolpix
How do you replace the battery door on the Nikon Coolpix L!?
Posted on Jan 30, 2010
Anonymous
  • 4 Answers
SOURCE: I need a new battery door for my nikon l 20
http://shop.thefotogeeks.com/nikoncoolpixl20batterydoorred.aspx
Posted on May 13, 2010
Where can I buy a replacement battery cover door for a Nikon Coolpix s7c please?
Hello again
There is one repair place that lists 700 different battery doors, but your is listed and out of stock. AliExpress also lists doors and sometimes they end up on eBay. Your best bet is Nikon direct.
https://www.google.com/search?q=replacement+battery+cover+door+for+a+Nikon+Coolpix+s7c
1helpful
How can i open the battery door of nikon coolpix l3
Most camera battery compartments have "raised lines" on the cover. They usually suggest that you put your finger or thumb on that surface and push with a sliding motion to open the cover. Again, there are many different models, but the Coolpix I have seen have that kind of opening device. Hope this helps!
THE BATTERY DOOR IN A NIKON COOLPIX L24 WONT CLOSE
This is a clear design flaw. There are hundreds of similar incidents. Just try searching for "Coolpix L22 battery door" Nikon refused even to sell me a replacement door, and asked me to send the whole camera to them for evaluation. Dozens of sellers on ebay and ali-express are selling the replacement door, but not Nikon-USA. They do not sell it. So beware when working with Nikon that they do not stand behind their products.
My nikon l20 bettery door is broken how can i fix this easily at home?
Hello Xavier,
You can repair the battery door of Nikon Coolpix L20 by using any adhesive. Please carefully apply the adhesive while repairing the battery door. If this will not works then you have to contact the service center for new battery door spare part.
2helpful
How to open battery door to recplace battery?
On the bottom of the camera you'll find a plastic tripod mount and the battery compartment. The door covering the battery compartment is fairly sturdy, and it has a locking mechanism. As you can see, the Coolpix 4600 and 5600 use two AA batteries.
2answers
You can get that replaced or repaired thru the list of Nikon Authorized service centers near you area. Just click the link::
http://www.nikonusa.com/Service-And-Support/Nikon-Authorized-Repair-List.page
Hope this helps.
6helpful
2answers
The little clip on the battery cover on my Nikon Coolpix 4300 has broken. I see I can buy a new one online, is it worth it?
Mine has broken as well. It appears this clip is just to keep the battery from falling out as you open the battery door. It will function perfectly fine without the clip. Just be careful not to drop the battery when you open the battery compartment.
Hope this helps,
-Tor
Nikon COOLPIX 3100 Digital Camera
I WOULD SUSPECT THAT THERE IS SOMETHING WRONG ON THIS NEW DOOR THAT THE BATTERIES ARE NOT MAKING GOOD CONTACT WITH THE DOOR AND THEREFORE NOT SUPPLYING POWER TO THE CAMERA. IF IT WORKED BEFORE THE DOOR WAS REPLACED, THERE MUST BE SOMETHING AT THAT POINT. I WOULD LOOK THERE FOR PROPER PRESSURE ON THE BATTERY OR BATTERIES.
8helpful
3answers
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
