Question about Freezers
My freezer is leaking water on the inside. How do I fix it
Posted by Maree Halloran on
  • Spencer warthen
    Spencer warthen Dec 23, 2018
    Hi Maree Halloran, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?MAKE and MODEL, exactly where is it leaking water(upper, lower, left, right) please give as much detail as possible.
Chris Huff
    Top Expert:
  • 6,289 Answers
Probably a clogged defrost drain
Posted on Dec 23, 2018
5 Related Answers
farfield
Farley Redfield
  • 462 Answers
SOURCE: FRIGIDAIRE SIDE BY SIDE WATER LEAKING FROM BOTTOM OF FREEZER DOOR
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
First lets decide where your leak actually is.
Areas to consider:
This is mostlikely a stopped up drain pan. A cold area that is not suppose to be cold likewhen you have a freezer coil that is suppose to be defrosting and is not... Seebelow for a more complete ideas list of things to check under Possibility.
The drain pan drain line is themost common. Inspect it and repair as needed, maybe its just a wrapper over the exit hole of the pan.
Some more Possibility's:
1 There is a drain that carries away the water under the cooling coils. Thesecoils are in the freezer section. Its most likely clogged or froze up.
2 The ice maker could be letting water leak all the way down look for an icy trail from the ice maker area.
3 Door gaskets are not sealing especially on the bottom of the door. Thisallows warmer air into the fridge section and it is condensation on floor underthe crisper.
If you check all of these items and still cant find it please post back andtell me what you did find. So I can help you more. Please rate me as much aspossible as Im trying to keep my average up and do the things that willactually educate and help people.
THANK you for using fixya and good luck..
Posted on Mar 22, 2009
Anonymous
  • 998 Answers
SOURCE: frs28zrg leaking. frozen water in bottom of
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model clean drains
Posted on Aug 15, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: leaking water inside bottom of fridge, fridge not keeping a cold
Sounds to me you are having a ice blockage and or defrost problem. When that happens water can not get outside of the refrigerator. If you look inside the rear of freezer you may see a frost line or layer building on rear panel. You may just need to begin manual defrost until we can get a look at the evaporator coils and condensate collection tray. Unplug and begin and let me know your model number. I can help if you like, Sea Breeze
Posted on Mar 19, 2010
Anonymous
  • 65 Answers
SOURCE: water leaking on inside - top shelves
The drain for the freezer is clogged. Unplug the frige and let it defrost. Pull the cover from the bottom front and note the drain pan. water should start draining into pan as the freezer defrosts. If Not the drain may be blocked. To access the drain remove icemaker then rear panel of freezer carefully, unplugging fan and ground wire. Look for drain in the middle under the coils. Look on outside back for the drain hose, this will help you locate the drain. Clear the drain of ice using hot water. You will hear it drain down the drain hose to the pan below.
Posted on Mar 29, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: water leak from freezer side
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 15, 2010
Not cooling, but fan inside running
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
Apr 06, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
Ice maker water leak in freezer. 8 yr old Amana std freezer on top, water actively leaking from ice maker into bin. Is it worth repairing?
Probably the solenoid (electric valve that opens and let the water from the supply line go into ice maker when It calls for it) is leaking and needs to be replaced ,it's not an expensive job. To make sure this is the problem ,shut of the ice maker by putting up the lever and wait a few hours and look inside the ice maker , if is water inside ,that's the problem ,if not the ice maker is the problem and has to be fix or replaced ; but is better to replace it ,won't be a big diference in cost.
Sep 27, 2009 | Freezers
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Hotpoint FZA80 freezer: water leaking
There's a drain hole inside the freezer in the bottom of the back wall ;probably is clogh .Put hot water into it to melt the ice and then blow it with air pressure;keep it clean pouring bleach throught it every 2 or 3 months.
Jul 18, 2009 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Ice at the bottom of freezer ice at the bottom of freezer, defrost water not draining
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 30, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Sep 27, 2008 | Freezers
Freezer Defrosting
After a defrost cycle the ice around the evaporator melts, that water goes out and lands in a tray under the refrigerator. But sometimes the tube gets clogged and water spills inside the freezer and if enough water accumulates, it will make it to the floor. To fix this problem look for a small hole inside the refrigerator and open it up using a can of compressed air. Hope this helps
Aug 05, 2008 | Freezers
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
264 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
