Washing Machines Logo
Johann Reyneke Posted on Dec 23, 2018
Miele G1220SC inlet valve and hose replacement
Miele G892 SC dishwasher stops 5 minutes after starting with flashing inlet/drain light. The drain is working because it drains at the beginning. Water is also coming in. None of the holes in the spray are...
If your Miele G892 SC dishwasher is stopping 5 minutes after starting with a flashing inlet/drain light, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
  1. Check the water pressure: Make sure that the water pressure is within the required range for the dishwasher (between 1.5 and 5 bar).
  2. Check the inlet hose: Make sure that the inlet hose is not kinked or clogged.
  3. Check the water inlet valve: Make sure that the water inlet valve is not clogged or malfunctioning.
  4. Check the water level sensor: Make sure that the water level sensor is not clogged or malfunctioning.
  5. Check the control board: Make sure that the control board is not malfunctioning.
  6. Check the temperature sensor: Make sure that the temperature sensor is not malfunctioning.
  7. Contact Miele customer support: If you have tried all the above steps and the dishwasher is still not working, it may be best to contact Miele customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Miele G892 SC is an older model dishwasher, which makes it harder to find replacement parts and professional repair services.
I have a Miele g7856 and I just replaced the drain hose now I get a F2E code ?
The F 2E code indicates insufficient water coming into the dishwasher. Thus you should check that the shut-off valves for the incoming water lines are open. Make sure that the incoming water pressure hasn't decreased and that the water lines aren't kinked or blocked. You should also check the water inlet filters (at the screw connection of the hose) and the flow restrictor insert in the waterproof system.
Since the dishwasher was working before the drain hose was replaced, closed shut-off valves and kinked hoses are particularly likely. You may also want to replace the inlet hoses themselves. (Some anti-burst hoses will restrict the water flow if they detect a leak.)
I hope this helps.
1helpful
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Miele washing machine w 487 check drain and check inlet
Clean out the pump trap. If you are on well water or just have very hard water, your inlet valve may be becoming constricted as well, remove the fill hoses from the back of the machine and shine a bright light into the valve to see if the screens are getting clogged with debris: In this case, follow the instructions the computer is giving you.
How do I replace water inlet control valve on a Miele G851 SCI
there is a box on the end of your inlet hose that contains two solenoids. that is called your water proof system hose. when you try to start a cycle, that box should vibrate as the solenoids get power and try to let the water in. if it vibrates, but no water passes, you need to replace the hose. the only place to get one is through miele. 800 843 7231, press 0 and ask for parts.
2helpful
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
2answers
Hello. My dishwasher (Miele G 579 SC) does not fill water enough. When filling is done I must fill manually with a bucket to get water to a sufficient level. What might be the problem? Kind regards...
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
6helpful
I have a G1220SC model. F11 shows on the panel,
F11 is a drain error.
Water outlet restricted.
** Check for kink in the drain hose.
** Clean the filter combination. (p.41)
** Clean the non-return valve (check valve) (p. 53)
** Check/clean the drain
Unplug the machine.
Disconnectthe drain where it enters the S bend from the sink. You may find thenozzle into the S bend is blocked. Probe it with a screwdriver andclear the blockage.
Plug in2_bing.gif the machine and re-try.
THIS MANUAL
may not be for your model - however it will give instructions on some of the steps above.
If all checks out - the pump will need replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
I have a miele G646 dishwasher whihs has sprung a leak into the bottom tray. Have dried it up and reset float switch but the water seems to be coming from a pipe on the left hand side of the machine. i...
It sounds like the leak is coming from the water intake hose.
The water intake house is located at the bottom sump of the dishwasher. To get to it the dishwasher has to be taken out and put on its back and the floor plan needs to come off. The intake hose runs from the inlet valve under your sink and attaches to the sump with a metal keeper. Overtime the part of the hose where the keeper is cracks (Normal wear and tear). As I recall the intake hose runs approx. $129.99 from Miele direct. It comes with an inlet valve on the hose. there is no separate or substitute hose you can use.
Good luck
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
