Https://www.repairclinic.com/Shop-For-Parts/a4b95c70/Hotpoint-Refrigerator-Handle-Parts there should be a couple of screws to take out one on top and bottom
SOURCE: door handle is loose on model#gsh22jftacc. how do you tighten?
If it's the same as the one we have (which is similar to the pic posted on yours) there's a plastic piece on the top and bottom of the handle that you have to pry up (gently) to get to them.
It looks like a line that runs horizontal across the handle, but it should come up with a little force (meaning it shouldn't require tools). You have to pry it from the side, not the top or bottom.
SOURCE: 2000 Kenmore Refrigerator 10659502993 I am looking for used door handles in white.
please buy new one! please
SOURCE: Can I remove the door handles from my refrigerator?
should be a screw at top and bottom contact points of handels, under decrotive covers. use small straight screwdriver or something like that to remove covers. be carfull not to scratch doors or covers (it's yours so it's your call)
SOURCE: Hotpoint side by side no dispensor door handle loose
Removing the door gasket would probably reveal screws to separate both shells of the door - warning: door gaskets are expensive and may be hard to find on a fridge that old, so be gentle with it.
JOAT
SOURCE: replacing door gaskets on model EF19MKXSN00
The gasket is held in place by metal strips on all 4 sides with a lot of screws. Loosen do not remove the screws and pull the gasket out from under it, Warm the new gasket in some hot water and tuck back under the retainers. Tighten the screws snug not overly tight. Use a heat gun or hair dryer to seat the new gasket and remove the wrinkles. Careful not to overheat and melt it.
Eric
