This tablet has a tiny Wi-Fi antenna and needs to be very close to an access point to connect. If you don't have any luck with it, try a hard reset, in case it's a settings issue. Be sure to back-up any data on the device first.
Hard-resetting a Crystal View tablet:
http://www.fixya.com/support/t15485926-hard_reset_crystalview_android_tablet
SOURCE: I have a crystalview xt android tablet or PC and my system UI stopped working
• You need to switch off your tablet
• Then press/hold power+volDOWN+home just keep pressing it
• Then it will switch on with a word start in it let go of the buttons you are holding
• You need to click on the VolDown twice so a recovery mode will appear.
• You need to click power so it will restart to recovery mode
• An android image will appear that has a red exclamation mark
• After which you need to hold down power and then press VolUP
• You need to use volume to scroll and press power to select "wipe data/factory reset"
• Then you need to scroll down again and press power to select "yes-erase all user data" This will now start your tablet to reboot Then it will switch off then switch on again.
