SOURCE: safety 1st walker
We did it! It is glued together, so you really have to pry it apart at the seam. We used a box cutter and then a butter knife to wiggle it apart (it does take some persistance). Once inside the batteries come out fairly easily. They are 3 (G13 A CNB). They look like watch batteries.
SOURCE: I cant change a battery in my Safety 1st walker
REMOVE THE SCREW AT THE REAR WHERE THE TOY ASSEMBLY PIVOTS,AND LET THE KNOB FALL OUT. THEN PUSH THE ASSEMBLY INWARD AND LIFT IT SLIGHTLY TO CLEAR CENTER LATCH SLOT. THE RAIL WILL THEN CLEAR AND THE ASSEMBLY WILL LIFT UP. CHANGE THE BATTERY, REVERSE THE ABOVE TO RE-ASSEMBLE.
SOURCE: I need the intruction manual to the Safety 1st
Ask the place you brought it from they shoudl be able to help you please.
SOURCE: how do you change the
Go to the Safety 1st site here:
http://www.safety1st.com/usa/eng/
At the bottom right is the customer support link for instructions. You will need the product number. If you do not have that you may need to use the Contact Us link for further assistance.
Thanks for using Fixya.
