Question about ASUS Cell Phones
How do i hard reset my asus Z00D Zenfone 2E? i forgot my password onto my phone
Posted by Tkaye Gilley on
Dave O.
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 101 Answers
  1. hold down the Power key for a short while to turn off your phone.
  2. Afterewards press and hold Volume Up + Power button simultaneously for a few seconds
  3. You can release held keys as soon as Asus logo appears on the screen.
  4. Then press Volume Down to select option "Recovery", and press Power button to confirm.
  5. When the Andorid logo appears on the screnn hold down the Power key
  6. While still holding this key press the Volume Up button once.
  7. Press Volume Down to choose "wipe data/factory reset", and then push the Power key to confirm.
  8. Select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select.
  9. To restart the phone, select "reboot system now".
  10. Success! The hard reset is done!
Posted on Sep 18, 2019
5 Related Answers
radarman19
  • 319 Answers
SOURCE: Can't unlock my phone,forgot my password
default code is last 4 digits of your phone number
Posted on Feb 12, 2008
Anonymous
  • 4 Answers
SOURCE: HOW TO HARD RESET MY PHONE LOCK FOR THE BEHOLD
This Indian dude does not know what he is talking about, the instructions he is giving you is to reset a Wing not the Behold below is the exact reset steps to reset the Behold.
Remove your sim card and turn you phone on, it should read no sim mode, press the phone button to get the numeric screen type in the following:
*2767*3855#
It will automaticall reset your phone wait a few minutes and your phone will reset to manufacturer defaults.
Posted on Sep 25, 2009
Anonymous
  • 31 Answers
SOURCE: Describe how to retrieve the asus pc password
If you can at least access root, then try the following...
All user encrypted passwords are stored in /etc/shadow file. The quick way to remove/delete a user password is pass --delete option to passwd command. First, login in as a root user.
Command to delete user password under Linux Type the following command to delete a user password:
# passwd --delete username
OR
# passwd -d username
Above command delete a user's password (make it empty). This is a quick way to disable a password for an account. It will set the named account passwordless. User will not able to login. It is also a good idea to setup user shell to nologin to avoid security related problems:# usrmod -s /sbin/nologin usernameFor example to delete password for user sweta, Type:# passwd -d sweta
# usrmod -s /sbin/nologin sweta
Posted on Mar 10, 2010
Oyelade Gbenga
  • 713 Answers
SOURCE: forgot the phone lock password ..
Hi,please dial this code on your phone, *#7370# code.This is a hard reset code,
Thanks and take care
Posted on May 04, 2010
Matsu
  • 385 Answers
SOURCE: forgot password
Hi, if you have Phone Password problem, you can use the following solution: http://www.fastgsm.com/en/samsung/samsung/s3353/unlock-code
Posted on Jun 06, 2012
Subject pronoun
I have an Asus ZenFone 2E...I have activated a pattern lock screen, I am unhappy with it, how can I deactivate it?
Sep 06, 2017 | Computers & Internet
How do I find out which model my asus zenphone is? Mine was stolen and a friend gavee this one. Serial number FCAZCY116275
Methods2: Enter [Settings] -> [ About ] -> [ Model number ] to check the model name of your phone.
Below table please check the correspondence between model name and model number. Model no. Model name ZenFone 4 T00I A400CG ZenFone 4 T00Q A450CG ZenFone 5 T00F A500CG ZenFone 5 T00J A501CG ZenFone 5 T00K A502CG ZenFone 5 T00P A500KL ZenFone 6 T00G A600CG ZenFone 6 Z002 A601CG ZenFone 2 Z00D ZE500CL ZenFone 2 Z008D ZE550ML ZenFone 2 Z00AD ZE551ML ZenFone C Z007 ZC451CG ZenFone Go Z00VD ZC500TG ZenFone2 Laser Z00ED ZE500KL ZenFone2 Laser Z00LD ZE550KL ZenFone Selfie Z00UD ZD551KL PadFone Infinity Lite T003 A80C New PadFone Infinity T004 A86 PadFone E T008 A68M PadFone mini 4.3 T00C A11 PadFone mini T00E PF400CG PadFone S T00N PF500KL
https://www.asus.com/us/support/FAQ/1014441
May 22, 2016 | ASUS Computers & Internet
Need unlock code
We do not have the code hear, contact your service provider.
Apr 23, 2016 | AT&T GoPhone Asus ZenFone 2E 4G with 16GB...
How do I unlock screen pattern if I forgot my pattern on Asus zenfone 4
Hi Sheena
If you forget your pattern:
1. After you fail to unlock the screen in pattern for 5 times (4 dots at least), there will be a text sign of "Forgot Pattern?" appeared on the lower-right of the screen.
2. Tap "Forgot Pattern?" and then enter your Google account and password saved in this phone to disable pattern lock.Note: If you do not log in your Google account or the device is not connected to internet before the phone is locked, you will need to perform factory data reset in DROIDBOOT mode to solve this problem.
If you forget your PIN or password:
1. To reset your PIN or password, you need to in advance log in your Google account in your device and have your phone connected to Internet as well as Location function enabled.
2. Then, visit website below: https://google.com/android/devicemanager
3. Choose your device that you want to reset PIN. After your device is located, tap "Lock" in the wondow and reset your PIN.
Apr 05, 2016 | ASUS Cell Phones
I cannot get into my facebook account as I forgot my password.
You can contact facebook through there sign in page. there is a section just for password issues.
Feb 02, 2016 | ASUS ZENFONE 5 Android 4.3 2GB 16GB...
I have an at&t asus zenfone and i need the screen unlock code.
Posts Tagged "AT&T Asus ZenFone 2E Unlock Code For Free"
unlockattfree.us/tag/att-asus-zenfone-2e-unlock-code-for-free/
Sep 10, 2015 - Want to Unlock Asus ZenFone 2E AT&T for free but can't find the FreeAT&T Asus ZenFone 2E Unlock Code for ... We have a good news for you. ... Turn on the AT&T Asus ZenFone 2E phone. it will show Unlock Code screen.
AT&T Asus ZenFone 2E Network Unlocking Code to work with T-Mobile ...
www.howardforums.com/.../1867755-Asus-ZenFone-2E-Network-Unloc...
Jul 27, 2015 - 1 post
Unlock AT&T Asus ZenFone 2E to use any where in the world with ... To reset your device, from the home screen, swipe down from the Notification bar. ... Congratulations you have managed to safely root your Asus Zenfone 2. How to Unlock At&t ASUS ZENFONE 2E ? ' At&t ...
1 post
Nov 20, 2015
AT&T Unlock AT&T ASUS Zenfone 2E
1 post
Oct 26, 2015
AT&T How to unlock by code AT&T ASUS ...
1 post
Aug 27, 2015
New ASUS Zenfone 2E available at Walmart
Jul 16, 2015
More results from www.howardforums.com
Dec 29, 2015 | ASUS Cell Phones
I have an at&T Asus zenfone and I need the screen unlock codes
1 post
Nov 20, 2015
1 post
Oct 26, 2015
1 post
Aug 27, 2015
Jul 16, 2015
Dec 29, 2015 | AT&T Cell Phones
I CAN NOT LOG ON TO MY ASUS Eee 900HA WINDOW ,I CHANGED MY PASSWORD,AFTER SHUTTING DOWN AND RESTARTING IT REFUSES TO RECOGNISE THE OLD AND NEW PASSWORD SO I CANT LOG ON TO THE WINDOW
If you have a Windows password reset disk, you can easily reset your Windows password with it. If not, you can follow the steps to create one. You just need an available computer linked to the Internet.
Step 1: Download and install
Windows Password Breaker with the available computer.
Step 2: Run the program and burn a Windows password reset disk. It could be burned onto a CD/DVD OR USB flash drive.
Step 3: Turn to your locked computer, insert the newly created CD or USB to your drive. Reboot the Computer and reset the Windows password.
It is easy and safe to use.
Jan 31, 2011 | ASUS Eee PC 900 Notebook
Cell Phones Logo
321 people viewed this question
Top ASUS Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an ASUS Cell Phone Expert? Answer questions, earn points and help others
