Watch this video, it may help
https://www.youtube.com/watch?v=kzakkfh0m2k
SOURCE: Delta 12 inch thickness planer blade change
Go to this link and at the bottom center of the page insert your model number. You will be able to download the manual for that machine.
Delta manual
If your question has been answered, or I fixed your problem, please take just a moment to rate this post...thanks!!
SOURCE: attic roof vent fan- brand unknown. need motor and blade
Any Blade will be ok if it will fit shaft and they all should be cosistant and of course the higher the amp the better quality.I like the Pro 3 model at Home depot but I believe the Pro 1 gable is the 12 inch blade,pro 3 is 17 inch houseing and maybe 12 inch also.
Please rate jj505 Guru
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
SOURCE: When I engage the PTO, the blades don't egage.
The first thing we need to to do is verify that there is adequate /(power 12 vdc) going to the electric clutch, you can do this by unplugging the clutch and check both wires 1 should have 12 volts and the other wire shoud read infinity to ground if this checks out replace the clutch, if you dont have 12vdc to the wire replace the relay
