SOURCE: Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked. the switched is located next to the hook that locks your door.
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
SOURCE: "door lock" light stays on and oven won't work
Same problems. When I removed the lock operating arm nothing happened. Motor is not operating. I've temporarily kluged it by tying the "unlock" (upper) switch circuit together and disconnecting one side of the power to the "locked" (lower) switch. At least we'll have an oven to use, but I'll have to come back and remove the lock motor assembly to find out what's really wrong.
BTW, if some knows those keyed-in service codes they could be useful.
SOURCE: Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
SOURCE: Interior oven light won't shut off.
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
